Full Version: Live tv for 5min then won't stop buffering
I have a problem with my live tv.
It happened sinds I upgraded my mediaportal tv-server from 1.23 to 1.3 and then 1.4 (even did a clean reinstal).
The problem is that i can't watch normally tv. Live tv works for about 5 minutes, then it says it's buffering, but the buffering stays at 0%.
When i stop the stream and start it again, it wil work but only for 5 minutes. The same problem pops up.
I did let xbmc buffer for 30 min without any result. It still says: Buffering 0%.
I did try to put the map timeshifting on various HDD, even on a ramdisk. They al gave the same problem. But the problem seems to be in XBMC because when i try to watch live tv with Mpextended, it works normal. I can watch tv for an hour without any buffering.
(the tv-server is installed on an other pc than xbmc)
with mediaportal 1.23 installed i had no problem at all, it was realy stable.
I hope somebody have an sollution, it's verry sad and i can't find any sollutionSad
Nobody?Sad
Nobody?Sad
