Full Version: xbmcubuntu on my pc
my current windows os just crashed so now i need to restart from scratch. i was thinking about using xbmcubuntu. all i need is the ability to use xbmc which is a given and setup plex media server so i can stream my videos while im away. also i would like for the toslink (optical) audio to work aswell. is this possible ill list my pc setup below.
amd x2 4400e (has sse3)
gigabyte ma78gm-us2h (ati 4200hd) i will be using integrated card
8gb 800mhz ddr2 ram
80gb ide hdd
thanks for any input
Looks very ample for xbmc. Ati doesn't have the best support in Linux, but it should be OK - throw a current low end nvidia card in there and you'll have a very capable htpc.
