Full Version: Switch between Intel <-> nVidia in XBMCBuntu?
Can anyone point me in the right direction? I have installed XBMCBuntu with a nVidia card installed. Now I have removed the card since basically the Intel HD2500 will suffice for this setup. The latest XBMCBuntu installation is suited for both nVidia and Intel graphics. But how can I configure it to work after removing the nVidia card? XBMC will not start because it's still expecting the nVidia card.
I know my way around the Linux command prompt, but lack the Xorg knowledge. Confused
sudo apt-get remove nvidia*
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.nvidia
sudo apt-get install --reinstall libva-intel-vaapi-driver
if necessary create a new xorg.conf.
