Using official remote to control XBMC installed on a Win 7 box, I'm having problems with some sort of interference. The cursor moves around the screen erratically and occasionally triggers a mouse click. This occurs whether the app is in use or not. Could there be some kind of wifi interference causing this?
I bet that you own an optical mouse :O
no ok... thinking on how the app/iOS works and looking to the code, seems near impossible this kind of behaviour. If there is a bug, with the cursor that moves around the screen erratically and occasionally, this could happen only if the app is in use, otherwise the app is frozen.
Out of curiosity: this happens even if you power off the iphone?
