Full Version: Subtitles encoding problem
Hello everyone,
I am using Android on MK808B device, and I have a problem with the subtitles. I have searched for the issue here on the forums, although not any of the solutions worked for me. The problem is that the subtitles which i download IN greek, do not display in greek, but on another language i can say. I had the same problem on my XBMC on my dektop pc, and i fixed it by changing the fonts in the xbmc files. Is there anyway to do the same on MK808B?
What can I do to fix this problem?
I might be on the wrong section in the forums, sorry in advance.
~Alex
I would try to post it in the android sub-forum.
As you say, if it happens also in the PC it's not an issue with the add-on, but with xbmc itself.
Sorry I can't be of much help.
I have just found the solution. I came across the solution again in the forums although I didnt do it right.
Go to System>Appearance>International and then change everything to your language and country. My country is Cyprus, and language is greek. As soon as i had picked Cyprus, it had automaticly chose Greek and other settings.
Thanks,
Alex
