Full Version: XBMC crashes after upgrading from Lucid to Precise
After upgrading from Lucid to Precise, XMBC crashes on startup. When starting XBMC, I observe initial XBMC black backgtound with XBMC logo and then trys to display a page of the default skin and then quickly exists. It appears that it is trying to displaying in full screen mode on startup.
I was able to turn debugging on thru the advancedsetting file.
Sequence for problem
1) upgrade from lucid to precise
2) run XBMC - crashes at startup
3) unistall; XMBC and delete all local and shared directories
4) reinstall XMBC
5) run XBMC - crashes at startup
System
Intel Atom 330 with NVIDA ION GPU
Ubuntu Linux Precise 12.04 64bits, 3.2.0-48 kernel
XBMC REPRO - LP-PPA-team-xbmc
Frodo
CRASH Log with debugging on
(MOD EDIT: Removed log contents from post. Please upload your log to a public paste site such as www.xbmclogs.com and post just the assigned URL to the log here.)
I found I could stop the crashing by removing the WINS resolution naming as an HOST option in the /etc/nsswitch.conf file.
Original Post: http://forum.xbmc.org/showthread.php?tid...pid1455615
Do not believe that this is a fix but rather a work around since WINS resolution should not cause a crash.
