2013-07-08, 02:06
Hi, I'm running 5 OpenELEC boxes, and I'm converting them all to use a shared MySQL DB.
I've followed the wiki and setup the DB, and used a Windows XBMC to populate all my sources, and scrape all my content.
I'm now ready to switch the OpenELEC boxes over to using the MySQL DB instance.
1) I did not see any instructions on what to do with sources.xml? In addition to copying advancedsettings.xml to all boxes, do I also need to copy sources.xml to every box, or will they pick the sources up from the DB?
- I'd like to keep the DB up to date, but have the player boxes go to sleep. Since the MySQL DB is up 24/7, can I run a XBMC instance on the MySQL server box, and install the XBMC Library Update addon, that will keep the DB fresh, and any player box that wakes up will not need to rescan content? If so, what do I do with sources.xml on player boxes, i.e. let them use the DB with existing content, but not try to update the entries?
P.
P.
