2013-07-08, 05:34
Hello All,
I built a Linux box (Ubuntu 12.04 64-bit) last year; I'm running Frodo 12.2 on it, and it all seems to work really well. I'm using an E350M1 (http://www.asrock.com/mb/overview.asp?Model=E350M1) board with 4GB of RAM, though some of this is used by the integrated graphics chip (AMD Radeon HD 6310). This runs pretty much everything without any problems, including Blu-Ray (quality) movies. The only time that I see dropped frames/jerkiness is when I play .MTS files from a full-HD video camera. I followed a guide that explained how to get VAAPI working with the Linux Catalyst drivers, so I'm assuming that this is because the HD6310 just doesn't have enough grunt to play files of this quality. I had a look at the stats when playing a Blu-Ray movie (The Dark Knight Rises), and when playing an .MTS:
Dark Knight Rises
D(Audio: aac, 48000Hz, stereo, s16) P(aq:99%, Kb/s: 155.98, att:0.0dB)
D(Video h264(Main), yuv420p, 1920x800 [SAR 1:1 DAR 12:5]) P(fr: 23.976, vq:99%, dc:ff-h264-vaapi, Mb/s:3.12, drop:17, pc:1)
C(ad:0.000, a/v: 0.033, edl:-, dcpu1% acpu: 6% vcpu: 6% cache:0 B 100%)
W(fps: 48.00 CPU0: 68.6% CPU1: 45.8%)
Home movie (.MTS)
D(Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, s16, 256 kb/s) P(aq:99%, Kb/s: 247.14, att:0.0dB)
D(Video: h264(High) (HDMV / 0x564D4448), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9] P(fr:50.000, vq:99%, dc:ff-h264-vaapi, Mb/s: 20.01, drop:1127, pc:none)
C(ac: 0.000, a/v: 0.170, edl:-, dcpu: 5% acpu 6% vcpu: 9% cache:0 B 92%)
W(fps: 48.00 CPU0: 79.6% CPU1: 44.7%)
I don't fully understand the stats, but a few things jump out at me from the .MTS: the 'High' H264 preset, the video bandwidth of 20 Mb/s, and the 50 Hz frame rate (as opposed to Main, 3 Mb/s and 24 fps for Dark Knight). I'm presuming that these conspire to ask more of the HD6310 than it can give, and it starts to drop frames. I guess that the CPUs (AMD E-350 dual-core 1.6GHz) are adequate, since they're not maxed out.
So, if I want to view .MTS files of this quality, I guess I need to invest in some new graphics hardware. I wondered if anyone had a feel for what (Linux-friendly) video card, which I could slot into the E350M1's PCI Express 2.0 x16, 4-lane slot, would be sufficient.
Advice would be much appreciated; I want to make sure that the video card is adequate before I buy it, assuming that this will fix the issue. Advice on tech tweaks would be great too; I'm wondering if the Frodo XBVA builds would help me at all . . .
Many thanks
Dark Knight Rises
Home movie (.MTS)
Many thanks
