Full Version: XBMC Amd (chipsett & radeon 3800 Series)
Hello peeps !!
i got this motherboard here!
http://www.gigabyte.no/products/page/mb/...fx-dq6_10/
And this Gpu here. http://www.amd.com/us/products/desktop/g...rview.aspx
im installing XBMC and everything Works ok.. until when i lunch the XBMC media center.. I just show the screen then I just pops out again! to thee login screen were i could choose (XBMCubuntu and XBMCmedia center..
maybe it need some sort of driver? `
maybe I've done something wrong ?
ive downloaded this ISO and burned it to a cd.. worked fine Wink
but still get this pop out when I try to "load" the media centre.
Any suggestion's ?
Ive run XBMC before... but on Intel machines.. now I've just god this amd here so I guess try this.. Smile
I think you need to run a special version (with muvh better AMD support) of XBMC. Try those builds:
http://forum.xbmc.org/showthread.php?tid=116996
(2013-07-08, 14:57)Robotica Wrote: [ -> ]I think you need to run a special version (with muvh better AMD support) of XBMC. Try those builds:
ahh thanks dude I will try it asap...
DUDE !!!! it worked like a charm!! Wink thanks!
Marked as Solved
