(2014-05-13, 22:09)mjbxx Wrote: [ -> ]Can the Keymap editor be used with the Fire TV? I have no idea how to access the keymap in the userdata folder on Fire TV. I can access it on Windows 7 but no dice with the Fire TV. Any help is appreciated.
I tried this addon with the fire tv and had partial success. I was able to map the context menu function and the info function to the buttons I wanted. However when I tried to map a button to show favorites and to show the codec info I got an error when I went to save it. I haven't looked at the log file yet. I tried an addon that emails you the xbmc log file, but that doesn't seem to work on the fire tv.
Jay
Is it possible to set a button that allows you to play the trailer for the movie you've selected, quickly and smoothly?
Thanks for a really good addon! <3
Thanks for this addon.
Am I able to remap the mouse wheel up/down? Wheel up/down seems to stop it waiting for a key-press but doesn't record it as being remapped.
(2014-05-23, 19:59)takoi Wrote: [ -> ] (2014-05-23, 18:56)jerndl Wrote: [ -> ]http://xbmclogs.com/show.php?id=208608
weird android permission issue. will be fixed in v0.9.6
I tried my keymappings with the new v0.9.6 and it worked great. Thanks for the great app. especially on the Firetv because it's a little bit more difficult to get access to the Android system to make manual changes to the keymaps. Also if I could ask another question. I am trying to map a key to Update the Video Library. I think i've done it manually before with the UpdateLibrary(database,[path]) builtin function. I can't seem find that function in your addon. Am I overlooking it or is it not there? If it's not there would it be possible to add it or is there another way to do it with your addon. Thanks again.
Jay
Is there anyway I can use this so an Apple TV remote via flirc (RaspBMC) can stop a video using the menu button but then be used as back button just like on the Apple TV?
Exactly what I was looking for. Takk!
Great work.
Just one suggestion, could you add the possibility to reset a shortcut or empty the key association.
When you're configuring your last custom key and hit enter twice, you have to delete the file and restart from scratch.
And don't ask me why it always happens with the last key
(2014-06-17, 22:58)T800 Wrote: [ -> ]Is there anyway I can use this so an Apple TV remote via flirc (RaspBMC) can stop a video using the menu button but then be used as back button just like on the Apple TV?
That's what the 'select window' option is for. Map global/back and fullscreen video/stop to the same key.
(2014-05-31, 20:15)jerndl Wrote: [ -> ] (2014-05-23, 19:59)takoi Wrote: [ -> ] (2014-05-23, 18:56)jerndl Wrote: [ -> ]http://xbmclogs.com/show.php?id=208608
Jay
I am also looking for the UpdateLibrary keymapping. I have also tried adding it manually to the "gen.xml" keymap but cant get it to work.
This is the string im using <key id ="VK_F1">UpdateLibrary(video)</key>
Im using Kodi 14.0 alpha2
Otherwise good job on the addon.
Thanks in advance
I don't think 'VK_F1' isn't a key id. It should be a number. Anyway, I have added update/clean library now (v0.9.7). PS: check out my other add-on Watchdog if you haven't already. It's for doing the library updating and cleaning automatically.
Wow thanks takoi for the superfast update, I appreciate it!
