2013-07-11, 15:03
According to the wiki, the Galaxy Tab 10.1 is supported by xbmc for android, but when I try to install it says that the device is not compatible.
I'm sure this has more to do with the custom ROM (it's jelly bean based), but is there anything specific in the code I can check to see if xbmc for android will definitely work or not work for my tablet? Is it searching for a specific processor type or android version?
Thanks in advance.
Thanks in advance.
