Full Version: Utorrent add on
"Failed to connect to Daemon, are you change settings now?"
This is the message I get whenever I try to use the uTorrent program. My utorrent is working fine in and of itself, and I believe I have the correct settings for it to work with xbmc (I had it going on a previous install, for a while at least before the same thing happened).
I'm thinking it's something in the uTorrent settings...
"Connection" - I've enabled upnp and NAT-NPMP port mapping, enabled a windows firewall exception, and set proxy server HTTP port 8080
"Remote" - I've enabled uTorrent remote access, and used password "password"
Under Web UI I've checked everything and used "admin" and "password" but it always sais "failed to connect to uTorrent remote."
I guess there are a few combinations of settings I haven't tried, but I'm getting confused on this one.
I wonder if this is linked to my other problem (Android remote app) maybe something in my system settings? It's just literally these two things away from perfection now!
Thanks for any help.
