Cool, thanks for addressing each item! By no means am I programmer, nor would I even know where to start. I wouldn't even say I'm an expert with XBMC either. I'm just an average end-user. However in the following I go into some detail, I'm not meaning to speak down to you in anyway (you obviously know a lot more about this than I do since you created it!) but I'm just trying to help others who are reading this and who may have stumbled across this cool feature of XBMC as well.
And sorry about the screen grab, it was nothing special, just showing the XBMC subtitle add-on. Like this:
http://forum.xbmc.org/showthread.php?tid=126495 (5th pic down in that thread)
This add-on can be activated from the Video Playback screen:
http://wiki.xbmc.org/index.php?title=Add..._Subtitles
Anyway:
1) OK yes, before you replied I figured out that I can still add my own formatted skip (0) edits (
http://wiki.xbmc.org/index.php?title=Edi...Player_EDL ) below the ###### section. And I don't have to insert them chronologically between lines X and Z. And I don't have to follow the ".003409" formatting. At first I thought that solved everything, but if it weren't for the following:
I still run into issues when a mute (1) and a skip's (0) time stamp overlap each other. When this happens the skip doesn't register at all, as confirmed in the codec info overlay: (
http://wiki.xbmc.org/index.php?title=Codecinfo ). The overlay shows how many c (cuts) and m (mutes) there are under "edl". This is probably a limitation with XBMC's internal video player (that somehow incorporates/relies on MPlayer, right?) I wonder if this limitation could be re-coded/fixed/handled differently by the core XBMC developers? So when this happens I need to go back into the .edl file and find where the corresponding mute is, which is often at the confusing destination of .00968493729 ?!?!
. Then I delete it and substitute it with the skip. Of course I can just watch the movie and figure it out, but I just figured the "1:55:20.32" format would be easiest.
I read fauxpaux's comment about the output. I thought the formatting I mentioned was fairly common, since it was taken from Mplayer. But I guess not. Perhaps a solution could be to create different kinds of formatted .edl's. But perhaps that's getting a little too far out of the boundaries of what this add-on is supposed to do in the first place? Although... I dunno, this *is* an XBMC addon and not an audacity addon.
Is there not other options that can create an .edl for audacity?
2) Cool!
3) Yea I have no idea if the different subtitle addons allow integration with other addons? It would be cool for sure. Of course the simple solution is for people to just use XBMC's subtitle add-on FIRST, make sure everything is synced up, and then use your add-on. But I guess being all-in-one is more ideal and adds a "coolness" factor.
4) Yea at first I thought that the addon wasn't recognizing any of my recently added movies at all. I almost didn't catch them sitting there all the way at the bottom of the list. It's almost like it's not using the Library View?
5) Yea, so again I have no idea how to program. So I'm no help to you. Anybody out there?!?! This guy from the other thread said he was willing to help:
http://forum.xbmc.org/showthread.php?tid...pid1232373
6) OK, now for a nit-picky thing that doesn't really matter... but:
When clicking through the following: Videos>Addons>Mute Profanity>Edit Movies/Edit TV Shows>*Name of Movie*
It pulls up a GUI that says "Play". Obviously hitting play activates it, but it would be less confusing if it said "Mute Profanity" right there.
7) Quick question, will XBMC use the .edl file when streaming over a network (smb, upnp, etc.)?
*EDIT* - I saw the github issue.
Unfortunately, I think the reason this feature hasn't made a lot of headway in the past is because people's personal opinions/views have overshadowed the function. And it's usually in a negative way. If I was a developer and created something and the only response I got back was; "why do you want to do that? that's dumb!". Then I would probably be discouraged from going too much further with it. For example, the banter usually goes something like this:
Quote:Why?
Quote:Because I don't want to see Bruce Willis' butt being scrubbed down in 12 Monkey's
But it doesn't end there, an opinion usually follows.
Quote:...and I don't think it adds anything to the film
Then somebody else interjects their opinion.
Quote:If you can't handle seeing Bruce Willis butt for 3 seconds then you shouldn't be watching 12 Monkey's.
And then it becomes this back and for thing about morals and blah, blah, blah. So there we go, I just provided the full play out of this conversation in advance for everyone.
Now please, let's not have it twice and let's keep this thread/topic about the addon/function itself. We ALL can agree on an improved XBMC and this function does just that.
