MovieJunky
Manual Configuration example for LiveTV: (from post #2)
<setting id="Channel_1_type" value="8" />
<setting id="Channel_1_1" value="I60159.labs.zap2it.com" />
<setting id="Channel_1_2" value="hdhomerun://xxxxxxxD-1/tuner1?channel=qam256:399000000&program=2" />
<setting id="Channel_1_3" value="xmltv" />
<setting id="Channel_1_rulecount" value="1" />
<setting id="Channel_1_changed" value="True" />
<setting id="Channel_1_time" value="0" />
<setting id="Channel_1_rule_1_id" value="1" />
<setting id="Channel_1_rule_1_opt_1" value="NY1 Live" />
# = PTV Channel Number
8 = LiveTV w/ XMLTV
Channel_#_type" value="8"
I60159.labs.zap2it.com = Channel ID found in your XMLTV file.
Channel_#_1" value="I60159.labs.zap2it.com"
This is the source of your LiveTV; examples include:
Channel_#_2" value="hdhomerun://xxxxxxxD-1/tuner1?channel=qam256:399000000&program=2".
Channel_#_2" value="smb://XXX/Hdhomerun XBMC/NY1.strm" -- Direct strm file (currently only one tuner is supported).
Channel_#_2" value="pvr://channels/tv/All TV channels/##.pvr" /> -- Direct link to your XBMC LiveTV plugin
I have hdhomrerun and pvr working in my pvtl setup up and will give you an example of each:
<setting id="Channel_72_type" value="8" />
<setting id="Channel_72_1" value="NA_SD_PC:48327_71009_18" />
<setting id="Channel_72_2" value="pvr://channels/tv/All TV channels/22.pvr" />
<setting id="Channel_72_3" value="xmltv" />
<setting id="Channel_72_rulecount" value="1" />
<setting id="Channel_72_changed" value="False" />
<setting id="Channel_72_time" value="0" />
<setting id="Channel_72_rule_1_id" value="1" />
<setting id="Channel_72_rule_1_opt_1" value="TCT Kids Sat" />
you will note at least one difference between mine and your previous post is I stopped the link after ".../22.pvr'
HDHomerun example from my setup
<setting id="Channel_20_type" value="8" />
<setting id="Channel_20_1" value="NA_SD_PC:72370_48996_19" />
<setting id="Channel_20_2" value="hdhomerun://1316F94B-2/tuner2?channel=auto:131&program=15" />
<setting id="Channel_20_3" value="xmltv" />
<setting id="Channel_20_rulecount" value="1" />
<setting id="Channel_20_changed" value="True" />
<setting id="Channel_20_time" value="0" />
<setting id="Channel_20_rule_1_id" value="1" />
<setting id="Channel_20_rule_1_opt_1" value="AETN Plus Live" />
Of course make sure your xmltv location is properly set.
In my opinion your entry should look like this:
<setting id="Channel_1_1" value="i60159.labs.zap2it.com" />
<setting id="Channel_1_2" value="pvr://channels/tv/All TV channels/3.pvr" />
<setting id="Channel_#_3" value="xmltv" />
<setting id="Channel_1_rule_1_opt_1" value="FOX" />
Is small i####.... correct on your zap2it entry?
