::Update::
Thanks to the help from user: earlieb, EPG Video Window will be available in the next update...
It requires some XBMC skin editing, so I wrote a very crude patch to automate the process. It should work for everyone? The patch can be found in PTVL's settings under Visual/EPG:
BTW: The patch applies to the current (in use) XBMC Skin, so if you change your skin you will have to patch again.
For now only the PTVL skin will include the video window, when I have time I work on all the skins...
i just installed and selected autostart or something and now it keeps rebooting.when it boots it says 'autostart pseudotv live service starting' and then instantly reboots again before i can change anything.Please help
EDIT; got into openelec files and deleted pseudotv
Anyone here good at putting together a python "
regular expression"?
Help would be appreciated, Thanks
I thought I saw in one of these posts where we can take .strm from other video addons we have installed. I just discovered the mashup addon and would like to add some of the cable channels (USA, TNT, etc) to my PTVL is that possible?
(2014-02-23, 02:14)stevedawg85 Wrote: [ -> ]I thought I saw in one of these posts where we can take .strm from other video addons we have installed. I just discovered the mashup addon and would like to add some of the cable channels (USA, TNT, etc) to my PTVL is that possible?
I never finished writing direct channel population via installed addons, but you can do it manually!
Because of forum rules, I do not support addons banned by this forum
You will need to rephrase the question, so that I don't hear from mods over the matter.
(2014-02-23, 03:43)Lunatixz Wrote: [ -> ] (2014-02-23, 02:14)stevedawg85 Wrote: [ -> ]I thought I saw in one of these posts where we can take .strm from other video addons we have installed. I just discovered the mashup addon and would like to add some of the cable channels (USA, TNT, etc) to my PTVL is that possible?
What I meant was, how can i get video from other addons onto PTVL
(2014-02-23, 03:47)stevedawg85 Wrote: [ -> ] (2014-02-23, 03:43)Lunatixz Wrote: [ -> ] (2014-02-23, 02:14)stevedawg85 Wrote: [ -> ]I thought I saw in one of these posts where we can take .strm from other video addons we have installed. I just discovered the mashup addon and would like to add some of the cable channels (USA, TNT, etc) to my PTVL is that possible?
Assuming the addon doesn't steal focus away from PTVL, and that it was coded correctly using "setResolvedUrl"
The easiest two ways:
- "Mylibrary" You can find support on their thread. Once you have the strms you're good to go!
"Favorite" favorite the link you like using xbmc then open favorite.xml and try using that link as a channel.
Because all addons are different, you will need to tinker with it.
(2014-02-22, 09:09)Lunatixz Wrote: [ -> ]::Update::
Thanks for this mr earlieb! It' really helps with my skins immersion. Keeps it up guys!
::Update::
I uploaded the new version that includes EPG Video Window (Currently only available for the PTVL skin).
Remember to run the patcher found in visual/epg settings. You can also run the patcher again to uninstall it (currently the only way to disable the video window).
(2014-02-23, 06:52)Lunatixz Wrote: [ -> ]::Update::
When i click on the patch..... Script failed videowindow.py
http://pastebin.com/kwwjC5Hn
(2014-02-23, 07:59)Lunatixz Wrote: [ -> ] (2014-02-23, 07:38)Redkiller223 Wrote: [ -> ] (2014-02-23, 06:52)Lunatixz Wrote: [ -> ]::Update::
When i click on the patch..... Script failed videowindow.py http://pastebin.com/kwwjC5Hn
fixed, git updated
Threw me a videowindow patch error
http://pastebin.com/7FMGjFG2
