Regarding ustvnow inclusion, if i have self created channels will it be possible to add ustvnow channels on top of these and have ustvnow epg? i.e if i have channels 1 to 50 already can i add ustvnow channels starting at 51 etc and get the epg from ustvnow (without have to use xmltv).
"sigh" still getting donor import failed.. temporarily disabling donor features. frustrating.
::Update::
Git updated with USTVnow Autotune, and a very early beta Direct Plugin chtype. This build also includes a few bug fixes...
I spent some time cleaning up post 2, any information you need can be found there!
Chtype = 15 "Direct Plugin" isn't finished so please hold back the bug reports! Not all plugin's are created equally, so it will take time to weed out problematic returns.
What will work?
plugins written correctly
a lot of plugins aren't written using suggested formatting. making a universal approach impossible.
Any plugin that uses "xbmcplugin.setResolvedUrl" and lists it's links as a "file" not "directory" will work.
Also I should mention there isn't any recursive features yet. So for now each link has to be direct to the list of content you want.
How do you find out what link to use?
easy way, favorite the directory and open favorites.xml with notepad. Copy and paste the link. You will have to clean it up a little tho!
(2014-03-31, 19:21)demarini Wrote: [ -> ]"sigh" still getting donor import failed.. temporarily disabling donor features. frustrating.
Donor works fine! you need to download latest and make sure you entered your user/pw correctly then don't forget to always activate/update donor features after each PTVL update!!
ok luna..dumb question
formating for user pass is username:password? or no spacing?
i get to donor features activated/updated, xbmc restart. after restar i get donor import failed, temporarily disabling donor features. i copied and pasted password to make sure correct pass. delete both folders, update etc etc still same as day one. can u please check password for correct spelling. thanks
(2014-03-31, 20:49)demarini Wrote: [ -> ]i get to donor features activated/updated, xbmc restart. after restar i get donor import failed, temporarily disabling donor features. i copied and pasted password to make sure correct pass. delete both folders, update etc etc still same as day one. can u please check password for correct spelling. thanks
I tested your user/pw in my setup... works fine!
when was the last time you updated pseudotv live? because I've asked twice and you haven't answered...
(2014-03-31, 20:32)Lunatixz Wrote: [ -> ] (2014-03-31, 19:21)demarini Wrote: [ -> ]"sigh" still getting donor import failed.. temporarily disabling donor features. frustrating.
I get the same error demarini gets, and I have followed your instructions to the T. I have yet to see any donor features since donating(maybe I'm getting donor commercials?), are there any additional plugins that are required to get them working.
(2014-03-31, 20:55)spyder Wrote: [ -> ] (2014-03-31, 20:32)Lunatixz Wrote: [ -> ] (2014-03-31, 19:21)demarini Wrote: [ -> ]"sigh" still getting donor import failed.. temporarily disabling donor features. frustrating.
You can't get some! it's all or nothing! so it either works or it's not!
May I ask... when was the last time you updated pseudotv live??
hey luna. i've updated every time u pushed a new update.
good to see its not the user pass. let me try again.
ok complete xbmc uninstall, reinstall. windows 7. deleted userdata on uninstall. xbmc pseudotv live sees ustvnow update, still after all this, donor import failed, temporarily disabling donor functions. etc. i am at a loss. this is frodo, 12.3 fresh with tv shows scraped. it activates and updates fine but when i go to modify channels it fails.
Lunatixz
Latest version is not creating channels for any of my playlists that i created for new tv episodes. Here's the log for channel 1 that it failed to create. Going back to 0.3.5 solves issue. With a previous 0.3.6 update it was creating the channels but it was generating playlists that were days out of date regarding new tv episodes.
http://pastebin.com/g6uubbUC
also a suggestion for the future, it would be cool to be able to view channels by categories in the tv guide. So if you clicked Movies, it would just display your movies channels etc. Each channel could have a category line in the settings2.xml file or something like that. Example here from windows media centre.
http://www.blogcdn.com/www.engadgethd.co..._03_ld.jpg
(2014-03-31, 22:18)kaiseruk Wrote: [ -> ]@Lunatixz
Where is the complete log?? if you are concerned about private info just PM me your log!! but don't pick and chose what I get to see, lol
With a complete log I could have checked to see if you installed one of the dependencies "script.common.plugin.cache"! which could be missing??
Please let me know... Thanks
(2014-03-31, 21:54)demarini Wrote: [ -> ]ok complete xbmc uninstall, reinstall. windows 7. deleted userdata on uninstall. xbmc pseudotv live sees ustvnow update, still after all this, donor import failed, temporarily disabling donor functions. etc. i am at a loss. this is frodo, 12.3 fresh with tv shows scraped. it activates and updates fine but when i go to modify channels it fails.
I have no clue!! I will make some changes to the code that will generate some errors. Then you can run it and send me the log!
Come to think of it... you haven't sent me any logs ?? Activate PTVL features, click ok then run ptvl. Exit ptvl and send me that log... thanks
Original log was full of pvr debug info so cherrypicked it!
PM sent with full log and pvr disabled
(2014-03-31, 23:00)kaiseruk Wrote: [ -> ]Original log was full of pvr debug info so cherrypicked it!
Thanks, problem fixed, and pushed to git!
those with donor import prompts, please run activation/update, then run ptvl... then send me logs please
