(2014-04-07, 21:40)Lunatixz Wrote: [ -> ] (2014-04-07, 21:31)frieten Wrote: [ -> ] (2014-04-07, 21:22)Lunatixz Wrote: [ -> ]Can you tell me why you are convinced its on my end? you do know that the time switch has absolutely nothing to do with it... a matter of fact it's disabled for chtypes 8 and 9
if you have a paid USTVnow account can you PM me the setting2.xml that is auto generated? I want to make sure that it's listing channels correctly! take in mind this has nothing to do with freezing channels.
this would only cause a channel not to play at all...
no need to pm you, its the second set of code is the settings2.xml that was autotuned from my list of premium channels.
and it could be on my end, who knows but you didn't even answer some of the questions i asked beforehand to help me try and figure out if it was.
for example:
1. since this only works in gotham, what do i do with all the Dependencies required in first post that are all for frodo?
2. does gotham have them all automatically?
3. Are you using Gotham beta 2 or 3?
4. do i need to update librtmp after upgrading to gotham or does it do that automatically? all the info i see for librtmp is in regards to frodo.
5. what settings excactly should i set in pseudo. all i am doing currently is leaving it at default, enabling debugging and running autotune with ustvnow.
feel free to ask me some questions so i can answer them also!
1, 2. You install them, Gotham wil update them if needed...
3. Gotham nighties
4. Yes, you need to update librtmp every time you update XBMC.
5. Default is optimal settings, but you should also add recommend changes found in post 2. and you should tweak your advancedsettings bgthreadingmode.
You should also make sure you don't have any xbmc widgets or services that cause issues with PTVL found in post 3.
thanks, i will update to gotham nightlie so we are on the same build.
i have copied your settings for advanded settings from the 2nd post, i dont see any info about bgthreadingmode
i dont have any widgets or services that would cause issues.
just went and tried this on a fresh install on my main PC. running windows 7
system specs:
I7 2600k
16gb ram
7970 GPU
intel SSD
followed all your instructions and tips, its a fresh gotham nightly install, with just everything needed to run autotune for ustvnow and its doing the EXCACT same thing as on my HTPC.
it doesnt play, and it freezes the xbmc when trying to change channel or exit.
can you please let me know what else i can try now.
starting to think this is an issue with me being premium user for ustvnow.
here is a log from my fresh install:
https://db.tt/r0lFoXO9
this is the settings2.xml generated:
<settings>
<setting id="Channel_1_type" value="8" />
<setting id="Channel_1_time" value="10" />
<setting id="Channel_1_1" value="I27.28460898.microsoft.com" />
<setting id="Channel_1_2" value="plugin://plugin.video.ustvnow/?name=ABC&mode=play" />
<setting id="Channel_1_3" value="ustvnow" />
<setting id="Channel_1_4" value="" />
<setting id="Channel_1_rulecount" value="1" />
<setting id="Channel_1_rule_1_id" value="1" />
<setting id="Channel_1_rule_1_opt_1" value="ABC USTVnow" />
<setting id="Channel_1_changed" value="False" />
<setting id="Channel_2_type" value="8" />
<setting id="Channel_2_time" value="10" />
<setting id="Channel_2_1" value="I21.28459588.microsoft.com" />
<setting id="Channel_2_2" value="plugin://plugin.video.ustvnow/?name=CBS&mode=play" />
<setting id="Channel_2_3" value="ustvnow" />
<setting id="Channel_2_4" value="" />
<setting id="Channel_2_rulecount" value="1" />
<setting id="Channel_2_rule_1_id" value="1" />
<setting id="Channel_2_rule_1_opt_1" value="CBS USTVnow" />
<setting id="Channel_2_changed" value="False" />
<setting id="Channel_3_type" value="8" />
<setting id="Channel_3_time" value="10" />
<setting id="Channel_3_1" value="I15.28461494.microsoft.com" />
<setting id="Channel_3_2" value="plugin://plugin.video.ustvnow/?name=CW&mode=play" />
<setting id="Channel_3_3" value="ustvnow" />
<setting id="Channel_3_4" value="" />
<setting id="Channel_3_rulecount" value="1" />
<setting id="Channel_3_rule_1_id" value="1" />
<setting id="Channel_3_rule_1_opt_1" value="CW USTVnow" />
<setting id="Channel_3_changed" value="False" />
<setting id="Channel_4_type" value="8" />
<setting id="Channel_4_time" value="10" />
<setting id="Channel_4_1" value="I43.28457987.microsoft.com" />
<setting id="Channel_4_2" value="plugin://plugin.video.ustvnow/?name=FOX&mode=play" />
<setting id="Channel_4_3" value="ustvnow" />
<setting id="Channel_4_4" value="" />
<setting id="Channel_4_rulecount" value="1" />
<setting id="Channel_4_rule_1_id" value="1" />
<setting id="Channel_4_rule_1_opt_1" value="FOX USTVnow" />
<setting id="Channel_4_changed" value="False" />
<setting id="Channel_5_type" value="8" />
<setting id="Channel_5_time" value="10" />
<setting id="Channel_5_1" value="I43.28457987.microsoft.com" />
<setting id="Channel_5_2" value="plugin://plugin.video.ustvnow/?name=FOX&mode=play" />
<setting id="Channel_5_3" value="ustvnow" />
<setting id="Channel_5_4" value="" />
<setting id="Channel_5_rulecount" value="1" />
<setting id="Channel_5_rule_1_id" value="1" />
<setting id="Channel_5_rule_1_opt_1" value="FOX USTVnow" />
<setting id="Channel_5_changed" value="False" />
<setting id="Channel_6_type" value="8" />
<setting id="Channel_6_time" value="10" />
<setting id="Channel_6_1" value="I8.28460167.microsoft.com" />
<setting id="Channel_6_2" value="plugin://plugin.video.ustvnow/?name=NBC&mode=play" />
<setting id="Channel_6_3" value="ustvnow" />
<setting id="Channel_6_4" value="" />
<setting id="Channel_6_rulecount" value="1" />
<setting id="Channel_6_rule_1_id" value="1" />
<setting id="Channel_6_rule_1_opt_1" value="NBC USTVnow" />
<setting id="Channel_6_changed" value="False" />
<setting id="Channel_7_type" value="8" />
<setting id="Channel_7_time" value="10" />
<setting id="Channel_7_1" value="I33.28455626.microsoft.com" />
<setting id="Channel_7_2" value="plugin://plugin.video.ustvnow/?name=PBS&mode=play" />
<setting id="Channel_7_3" value="ustvnow" />
<setting id="Channel_7_4" value="" />
<setting id="Channel_7_rulecount" value="1" />
<setting id="Channel_7_rule_1_id" value="1" />
<setting id="Channel_7_rule_1_opt_1" value="PBS USTVnow" />
<setting id="Channel_7_changed" value="False" />
<setting id="Channel_8_type" value="8" />
<setting id="Channel_8_time" value="10" />
<setting id="Channel_8_1" value="I238.28455933.microsoft.com" />
<setting id="Channel_8_2" value="plugin://plugin.video.ustvnow/?name=My9&mode=play" />
<setting id="Channel_8_3" value="ustvnow" />
<setting id="Channel_8_4" value="" />
<setting id="Channel_8_rulecount" value="1" />
<setting id="Channel_8_rule_1_id" value="1" />
<setting id="Channel_8_rule_1_opt_1" value="My9 USTVnow" />
<setting id="Channel_8_changed" value="False" />
<setting id="Channel_9_type" value="8" />
<setting id="Channel_9_time" value="10" />
<setting id="Channel_9_1" value="I238.28455933.microsoft.com" />
<setting id="Channel_9_2" value="plugin://plugin.video.ustvnow/?name=My9&mode=play" />
<setting id="Channel_9_3" value="ustvnow" />
<setting id="Channel_9_4" value="" />
<setting id="Channel_9_rulecount" value="1" />
<setting id="Channel_9_rule_1_id" value="1" />
<setting id="Channel_9_rule_1_opt_1" value="My9 USTVnow" />
<setting id="Channel_9_changed" value="False" />
<setting id="Channel_10_type" value="8" />
<setting id="Channel_10_time" value="10" />
<setting id="Channel_10_1" value="I140.28455954.microsoft.com" />
<setting id="Channel_10_2" value="plugin://plugin.video.ustvnow/?name=ESPN&mode=play" />
<setting id="Channel_10_3" value="ustvnow" />
<setting id="Channel_10_4" value="" />
<setting id="Channel_10_rulecount" value="1" />
<setting id="Channel_10_rule_1_id" value="1" />
<setting id="Channel_10_rule_1_opt_1" value="ESPN USTVnow" />
<setting id="Channel_10_changed" value="False" />
<setting id="Channel_11_type" value="8" />
<setting id="Channel_11_time" value="10" />
<setting id="Channel_11_1" value="I108.28460884.microsoft.com" />
<setting id="Channel_11_2" value="plugin://plugin.video.ustvnow/?name=Lifetime&mode=play" />
<setting id="Channel_11_3" value="ustvnow" />
<setting id="Channel_11_4" value="" />
<setting id="Channel_11_rulecount" value="1" />
<setting id="Channel_11_rule_1_id" value="1" />
<setting id="Channel_11_rule_1_opt_1" value="Lifetime USTVnow" />
<setting id="Channel_11_changed" value="False" />
<setting id="Channel_12_type" value="8" />
<setting id="Channel_12_time" value="10" />
<setting id="Channel_12_1" value="I186.28455157.microsoft.com" />
<setting id="Channel_12_2" value="plugin://plugin.video.ustvnow/?name=National Geographic Channel&mode=play" />
<setting id="Channel_12_3" value="ustvnow" />
<setting id="Channel_12_4" value="" />
<setting id="Channel_12_rulecount" value="1" />
<setting id="Channel_12_rule_1_id" value="1" />
<setting id="Channel_12_rule_1_opt_1" value="National Geographic Channel USTVnow" />
<setting id="Channel_12_changed" value="False" />
<setting id="Channel_13_type" value="8" />
<setting id="Channel_13_time" value="10" />
<setting id="Channel_13_1" value="I176.28460558.microsoft.com" />
<setting id="Channel_13_2" value="plugin://plugin.video.ustvnow/?name=Cartoon Network&mode=play" />
<setting id="Channel_13_3" value="ustvnow" />
<setting id="Channel_13_4" value="" />
<setting id="Channel_13_rulecount" value="1" />
<setting id="Channel_13_rule_1_id" value="1" />
<setting id="Channel_13_rule_1_opt_1" value="Cartoon Network USTVnow" />
<setting id="Channel_13_changed" value="False" />
<setting id="Channel_14_type" value="8" />
<setting id="Channel_14_time" value="10" />
<setting id="Channel_14_1" value="I120.28457181.microsoft.com" />
<setting id="Channel_14_2" value="plugin://plugin.video.ustvnow/?name=History&mode=play" />
<setting id="Channel_14_3" value="ustvnow" />
<setting id="Channel_14_4" value="" />
<setting id="Channel_14_rulecount" value="1" />
<setting id="Channel_14_rule_1_id" value="1" />
<setting id="Channel_14_rule_1_opt_1" value="History USTVnow" />
<setting id="Channel_14_changed" value="False" />
<setting id="Channel_15_type" value="8" />
<setting id="Channel_15_time" value="10" />
<setting id="Channel_15_1" value="I107.28455994.microsoft.com" />
<setting id="Channel_15_2" value="plugin://plugin.video.ustvnow/?name=Comedy Central&mode=play" />
<setting id="Channel_15_3" value="ustvnow" />
<setting id="Channel_15_4" value="" />
<setting id="Channel_15_rulecount" value="1" />
<setting id="Channel_15_rule_1_id" value="1" />
<setting id="Channel_15_rule_1_opt_1" value="Comedy Central USTVnow" />
<setting id="Channel_15_changed" value="False" />
<setting id="Channel_16_type" value="8" />
<setting id="Channel_16_time" value="10" />
<setting id="Channel_16_1" value="I107.28455994.microsoft.com" />
<setting id="Channel_16_2" value="plugin://plugin.video.ustvnow/?name=Comedy Central&mode=play" />
<setting id="Channel_16_3" value="ustvnow" />
<setting id="Channel_16_4" value="" />
<setting id="Channel_16_rulecount" value="1" />
<setting id="Channel_16_rule_1_id" value="1" />
<setting id="Channel_16_rule_1_opt_1" value="Comedy Central USTVnow" />
<setting id="Channel_16_changed" value="False" />
<setting id="Channel_17_type" value="8" />
<setting id="Channel_17_time" value="10" />
<setting id="Channel_17_1" value="I129.28455611.microsoft.com" />
<setting id="Channel_17_2" value="plugin://plugin.video.ustvnow/?name=Bravo&mode=play" />
<setting id="Channel_17_3" value="ustvnow" />
<setting id="Channel_17_4" value="" />
<setting id="Channel_17_rulecount" value="1" />
<setting id="Channel_17_rule_1_id" value="1" />
<setting id="Channel_17_rule_1_opt_1" value="Bravo USTVnow" />
<setting id="Channel_17_changed" value="False" />
<setting id="Channel_18_type" value="8" />
<setting id="Channel_18_time" value="10" />
<setting id="Channel_18_1" value="I118.28459333.microsoft.com" />
<setting id="Channel_18_2" value="plugin://plugin.video.ustvnow/?name=AETV&mode=play" />
<setting id="Channel_18_3" value="ustvnow" />
<setting id="Channel_18_4" value="" />
<setting id="Channel_18_rulecount" value="1" />
<setting id="Channel_18_rule_1_id" value="1" />
<setting id="Channel_18_rule_1_opt_1" value="AETV USTVnow" />
<setting id="Channel_18_changed" value="False" />
<setting id="Channel_19_type" value="8" />
<setting id="Channel_19_time" value="10" />
<setting id="Channel_19_1" value="I105.28459373.microsoft.com" />
<setting id="Channel_19_2" value="plugin://plugin.video.ustvnow/?name=USA&mode=play" />
<setting id="Channel_19_3" value="ustvnow" />
<setting id="Channel_19_4" value="" />
<setting id="Channel_19_rulecount" value="1" />
<setting id="Channel_19_rule_1_id" value="1" />
<setting id="Channel_19_rule_1_opt_1" value="USA USTVnow" />
<setting id="Channel_19_changed" value="False" />
<setting id="Channel_20_type" value="8" />
<setting id="Channel_20_time" value="10" />
<setting id="Channel_20_1" value="I170.28458210.microsoft.com" />
<setting id="Channel_20_2" value="plugin://plugin.video.ustvnow/?name=Nickelodeon&mode=play" />
<setting id="Channel_20_3" value="ustvnow" />
<setting id="Channel_20_4" value="" />
<setting id="Channel_20_rulecount" value="1" />
<setting id="Channel_20_rule_1_id" value="1" />
<setting id="Channel_20_rule_1_opt_1" value="Nickelodeon USTVnow" />
<setting id="Channel_20_changed" value="False" />
<setting id="Channel_21_type" value="8" />
<setting id="Channel_21_time" value="10" />
<setting id="Channel_21_1" value="I136.28455996.microsoft.com" />
<setting id="Channel_21_2" value="plugin://plugin.video.ustvnow/?name=FX&mode=play" />
<setting id="Channel_21_3" value="ustvnow" />
<setting id="Channel_21_4" value="" />
<setting id="Channel_21_rulecount" value="1" />
<setting id="Channel_21_rule_1_id" value="1" />
<setting id="Channel_21_rule_1_opt_1" value="FX USTVnow" />
<setting id="Channel_21_changed" value="False" />
<setting id="Channel_22_type" value="8" />
<setting id="Channel_22_time" value="10" />
<setting id="Channel_22_1" value="I184.28458285.microsoft.com" />
<setting id="Channel_22_2" value="plugin://plugin.video.ustvnow/?name=Animal Planet&mode=play" />
<setting id="Channel_22_3" value="ustvnow" />
<setting id="Channel_22_4" value="" />
<setting id="Channel_22_rulecount" value="1" />
<setting id="Channel_22_rule_1_id" value="1" />
<setting id="Channel_22_rule_1_opt_1" value="Animal Planet USTVnow" />
<setting id="Channel_22_changed" value="False" />
<setting id="Channel_23_type" value="9" />
<setting id="Channel_23_time" value="0" />
<setting id="Channel_23_1" value="5400" />
<setting id="Channel_23_2" value="plugin://plugin.video.ustvnow/?name=Discovery Channel&mode=play" />
<setting id="Channel_23_3" value="Discovery Channel" />
<setting id="Channel_23_4" value="XMLTV DATA NOT FOUND" />
<setting id="Channel_23_rulecount" value="1" />
<setting id="Channel_23_rule_1_id" value="1" />
<setting id="Channel_23_rule_1_opt_1" value="Discovery Channel USTVnow" />
<setting id="Channel_23_changed" value="False" />
<setting id="Channel_24_type" value="8" />
<setting id="Channel_24_time" value="10" />
<setting id="Channel_24_1" value="I208.28459524.microsoft.com" />
<setting id="Channel_24_2" value="plugin://plugin.video.ustvnow/?name=CNBC&mode=play" />
<setting id="Channel_24_3" value="ustvnow" />
<setting id="Channel_24_4" value="" />
<setting id="Channel_24_rulecount" value="1" />
<setting id="Channel_24_rule_1_id" value="1" />
<setting id="Channel_24_rule_1_opt_1" value="CNBC USTVnow" />
<setting id="Channel_24_changed" value="False" />
<setting id="Channel_25_type" value="9" />
<setting id="Channel_25_time" value="0" />
<setting id="Channel_25_1" value="5400" />
<setting id="Channel_25_2" value="plugin://plugin.video.ustvnow/?name=AMC&mode=play" />
<setting id="Channel_25_3" value="AMC" />
<setting id="Channel_25_4" value="XMLTV DATA NOT FOUND" />
<setting id="Channel_25_rulecount" value="1" />
<setting id="Channel_25_rule_1_id" value="1" />
<setting id="Channel_25_rule_1_opt_1" value="AMC USTVnow" />
<setting id="Channel_25_changed" value="False" />
<setting id="Channel_26_type" value="8" />
<setting id="Channel_26_time" value="10" />
<setting id="Channel_26_1" value="I138.28456676.microsoft.com" />
<setting id="Channel_26_2" value="plugin://plugin.video.ustvnow/?name=TNT&mode=play" />
<setting id="Channel_26_3" value="ustvnow" />
<setting id="Channel_26_4" value="" />
<setting id="Channel_26_rulecount" value="1" />
<setting id="Channel_26_rule_1_id" value="1" />
<setting id="Channel_26_rule_1_opt_1" value="TNT USTVnow" />
<setting id="Channel_26_changed" value="False" />
<setting id="Channel_27_type" value="8" />
<setting id="Channel_27_time" value="10" />
<setting id="Channel_27_1" value="I139.28459055.microsoft.com" />
<setting id="Channel_27_2" value="plugin://plugin.video.ustvnow/?name=TBS&mode=play" />
<setting id="Channel_27_3" value="ustvnow" />
<setting id="Channel_27_4" value="" />
<setting id="Channel_27_rulecount" value="1" />
<setting id="Channel_27_rule_1_id" value="1" />
<setting id="Channel_27_rule_1_opt_1" value="TBS USTVnow" />
<setting id="Channel_27_changed" value="False" />
<setting id="Channel_28_type" value="9" />
<setting id="Channel_28_time" value="0" />
<setting id="Channel_28_1" value="5400" />
<setting id="Channel_28_2" value="plugin://plugin.video.ustvnow/?name=SPIKE TV&mode=play" />
<setting id="Channel_28_3" value="SPIKE TV" />
<setting id="Channel_28_4" value="XMLTV DATA NOT FOUND" />
<setting id="Channel_28_rulecount" value="1" />
<setting id="Channel_28_rule_1_id" value="1" />
<setting id="Channel_28_rule_1_opt_1" value="SPIKE TV USTVnow" />
<setting id="Channel_28_changed" value="False" />
<setting id="Channel_29_type" value="8" />
<setting id="Channel_29_time" value="10" />
<setting id="Channel_29_1" value="I205.28455736.microsoft.com" />
<setting id="Channel_29_2" value="plugin://plugin.video.ustvnow/?name=Fox News Channel&mode=play" />
<setting id="Channel_29_3" value="ustvnow" />
<setting id="Channel_29_4" value="" />
<setting id="Channel_29_rulecount" value="1" />
<setting id="Channel_29_rule_1_id" value="1" />
<setting id="Channel_29_rule_1_opt_1" value="Fox News Channel USTVnow" />
<setting id="Channel_29_changed" value="False" />
<setting id="Channel_30_type" value="8" />
<setting id="Channel_30_time" value="0" />
<setting id="Channel_30_1" value="I122.28456824.microsoft.com" />
<setting id="Channel_30_2" value="plugin://plugin.video.ustvnow/?name=Syfy&mode=play" />
<setting id="Channel_30_3" value="ustvnow" />
<setting id="Channel_30_4" value="" />
<setting id="Channel_30_rulecount" value="1" />
<setting id="Channel_30_rule_1_id" value="1" />
<setting id="Channel_30_rule_1_opt_1" value="Syfy USTVnow" />
<setting id="Channel_30_changed" value="False" />
<setting id="Channel_31_type" value="8" />
<setting id="Channel_31_time" value="0" />
<setting id="Channel_31_1" value="I200.28456220.microsoft.com" />
<setting id="Channel_31_2" value="plugin://plugin.video.ustvnow/?name=CNN&mode=play" />
<setting id="Channel_31_3" value="ustvnow" />
<setting id="Channel_31_4" value="" />
<setting id="Channel_31_rulecount" value="1" />
<setting id="Channel_31_rule_1_id" value="1" />
<setting id="Channel_31_rule_1_opt_1" value="CNN USTVnow" />
<setting id="Channel_31_changed" value="False" />
<setting id="LastExitTime" value="1396902283" />
<setting id="LastResetTime" value="1396902417" />
</settings>
(2014-04-07, 22:39)frieten Wrote: [ -> ]can you please let me know what else i can try now.
did you update your librtmp.dill?
You said you were running default settings? it looks like you have background updating turned on? set it to minimal.
(2014-04-07, 22:52)Lunatixz Wrote: [ -> ] (2014-04-07, 22:39)frieten Wrote: [ -> ]can you please let me know what else i can try now.
oh shit, i forgot that with the new install. i'll do that now and report back. im just using the one posted in your post thats the correct one yes? (for windows, direct download)
will check the background updating setting also and let you know.
(2014-04-07, 22:56)frieten Wrote: [ -> ] (2014-04-07, 22:52)Lunatixz Wrote: [ -> ] (2014-04-07, 22:39)frieten Wrote: [ -> ]can you please let me know what else i can try now.
I just check autotune with full access to USTVnow other then a few channels not finding xmltv data ( i'll fix that when I get a chance). I have bitrate maxed and it's performing really well. channels load and start as expected.
(2014-04-07, 23:09)Lunatixz Wrote: [ -> ] (2014-04-07, 22:56)frieten Wrote: [ -> ] (2014-04-07, 22:52)Lunatixz Wrote: [ -> ]did you update your librtmp.dill?
Not really impressed with their hd service... seems to only be fore ota channels.
ok so its not because of my premium then as to why its not working for me. grr. i just tried 3 more times with background set to minimal, it did the same, and also tried it with off. not sure if it means anything but when the screen loads i get this: see how it has the "seeking" ever time it opens that is up there always with a different seek time. have no idea why it would be doing this and what could be causing it?
have sent you another log also.
(2014-04-07, 23:27)frieten Wrote: [ -> ] (2014-04-07, 23:09)Lunatixz Wrote: [ -> ] (2014-04-07, 22:56)frieten Wrote: [ -> ]oh shit, i forgot that with the new install. i'll do that now and report back. im just using the one posted in your post thats the correct one yes? (for windows, direct download)
there shouldn't be a seek, seek is disabled for chtype 8 and 9
(2014-04-08, 00:05)Lunatixz Wrote: [ -> ] (2014-04-07, 23:27)frieten Wrote: [ -> ] (2014-04-07, 23:09)Lunatixz Wrote: [ -> ]I just check autotune with full access to USTVnow other then a few channels not finding xmltv data ( i'll fix that when I get a chance). I have bitrate maxed and it's performing really well. channels load and start as expected.
so whats it doing then? and how can i stop it from doing it, perhaps this is the issue.
edit: found others with a similar issue, im thinking this is the cause
http://forum.xbmc.org/showthread.php?tid=187840
(2014-04-08, 00:35)frieten Wrote: [ -> ] (2014-04-08, 00:05)Lunatixz Wrote: [ -> ] (2014-04-07, 23:27)frieten Wrote: [ -> ]ok so its not because of my premium then as to why its not working for me. grr. i just tried 3 more times with background set to minimal, it did the same, and also tried it with off. not sure if it means anything but when the screen loads i get this: see how it has the "seeking" ever time it opens that is up there always with a different seek time. have no idea why it would be doing this and what could be causing it?
This isn't anything new... seeks been a known issue and was disabled for chtype 8 and 9 a long time ago...
I can't even duplicate your problem... because seek is disabled, is anyone else out there noticing seeking on chtypes 8 or 9?
It maybe something unique to your remote setup?
(2014-04-08, 00:51)Lunatixz Wrote: [ -> ] (2014-04-08, 00:35)frieten Wrote: [ -> ] (2014-04-08, 00:05)Lunatixz Wrote: [ -> ]there shouldn't be a seek, seek is disabled for chtype 8 and 9
im not even using a remote on the new setup, im doing all this testing on the fresh clean install which is running on my main PC, just using a keyboard. and yeah its for 100% sure an issue with this seeking, its for some reason seeking on startup and that is causing it to freeze. i just replicated it in ustvnow plugin by trying to seek a stream and it froze also. guess im going to have to wait for a fix, hopefully in one of the new nightlies soon.
at least we have diagnosed what the issue is, but if you say it is supposed to disable seeking for those channel types i dont know why it is doing it, i dont even press any buttons at all it just loads up and does that straight away.
might try disabling keyboard inputs and just do it from mouse
(2014-04-08, 01:39)frieten Wrote: [ -> ] (2014-04-08, 00:51)Lunatixz Wrote: [ -> ] (2014-04-08, 00:35)frieten Wrote: [ -> ]so whats it doing then? and how can i stop it from doing it, perhaps this is the issue.
What's odd is I don't have a seek problem, even when using the premium account... Maybe its because I'm in the ustvnow timezone. Maybe ustvnow tries to time shift based on region??
Is your PTVL set for realtime? What mode are you in?
(2014-04-08, 01:50)Lunatixz Wrote: [ -> ] (2014-04-08, 01:39)frieten Wrote: [ -> ] (2014-04-08, 00:51)Lunatixz Wrote: [ -> ]This isn't anything new... seeks been a known issue and was disabled for chtype 8 and 9 a long time ago...
yeah it could be, it is set in realtime as that is default. what other option could i try? resume?
EDIT: tried all the different options all did the same thing. even tried setting my PC clock to US time lol same deal.
what us time did you use? lol
PC time wouldnt matter...
Um us east? What time should I try lol. Really doubt this will do anything but worth a go I suppose
