(2014-04-30, 14:38)acelove Wrote: [ -> ]Hey Luna. I was messing about with backdrops for my own XBMC client kinda making it look cohesive.
If you want to use the images, feel free.
Is this from a skin you created for Ptvl?
::Update::
Going to be pushing an update soon, there is a lot of changes... So some extra steps need to be taken when upgrading!
1. Make sure you clean install by deleting (not uninstalling) your addon folder (addon\script.pseudotv.live).
2. After installing you will need to open settings and click (default) to reset all settings... (This is a must)!
3. Remember to reconfigure settings and reactivate donor settings.
(2014-04-30, 14:49)Lunatixz Wrote: [ -> ] (2014-04-30, 14:38)acelove Wrote: [ -> ]Hey Luna. I was messing about with backdrops for my own XBMC client kinda making it look cohesive.
I wish I was that talented
It's just a backdrop for XBMC's main menu if wanted to add PSTV to the main section.
(2014-04-30, 20:30)acelove Wrote: [ -> ] (2014-04-30, 14:49)Lunatixz Wrote: [ -> ] (2014-04-30, 14:38)acelove Wrote: [ -> ]Hey Luna. I was messing about with backdrops for my own XBMC client kinda making it look cohesive.
I wish I was that talented It's just a backdrop for XBMC's main menu if wanted to add PSTV to the main section.
I will use it for a promo shot
Can I get a png of just the blue squares, I will make a skin with it...
::Update::
Aurora and Concast Skins temporarily removed
V.0.3.8
(2014-04-30, 23:37)Lunatixz Wrote: [ -> ]::Update::
V.0.3.8
When trying to install, get an error saying the addon does not have the correct structure
*edit* if i rename the zip to "script.pseudotv.live.zip" incorrect structure. A fresh download that has not been renamed says that i do not meet dependencies. Running openelec beta 7, XBMCGotham RC1
V.0.3.8
The unicode issue fixed with the last update
Thanks Lunatixz
(2014-05-01, 00:14)Lunatixz Wrote: [ -> ] (2014-05-01, 00:08)Dec64 Wrote: [ -> ] (2014-04-30, 23:37)Lunatixz Wrote: [ -> ]::Update::
V.0.3.8
Your not installing as per instructions in post 1
I was/am. I update/install to the latest version often. I just unpacked and transferred it over directly to the addons folder and its fine.
(2014-05-01, 00:24)tromy Wrote: [ -> ] (2014-04-30, 23:37)Lunatixz Wrote: [ -> ]::Update::
V.0.3.8
Thanks Lunatixz
Nope, You mentioned a problem... but I didn't see a log!!
(2014-05-01, 00:25)Dec64 Wrote: [ -> ] (2014-05-01, 00:14)Lunatixz Wrote: [ -> ] (2014-05-01, 00:08)Dec64 Wrote: [ -> ]When trying to install, get an error saying the addon does not have the correct structure
Problem fixed, beta (common.cache, and simple.downloader) not in the official repo
re download and try again
(2014-05-01, 00:25)Lunatixz Wrote: [ -> ] (2014-05-01, 00:24)tromy Wrote: [ -> ] (2014-04-30, 23:37)Lunatixz Wrote: [ -> ]::Update::
V.0.3.8
Thanks Lunatixz
I doubled checked the major issue (freezes,black screen...) gone
One minor issue:The titles of the episodes of tv shows can't be displayed at tv overlay+epg window(because of the unicode...)
p.s. I've posted a log in my previous post,you mean you didn't have time to see it?
(2014-05-01, 01:11)tromy Wrote: [ -> ] (2014-05-01, 00:25)Lunatixz Wrote: [ -> ] (2014-05-01, 00:24)tromy Wrote: [ -> ]The unicode issue fixed with the last update
Thanks Lunatixz
I didn't see a log send me link again
(2014-05-01, 04:31)mrpcpro Wrote: [ -> ]instead of the names of the show, in the EPG it shows SMB:
http://1drv.ms/1pQCbtS
Need details, what chtype? Log? Can I see the m3u for that channel?
