I thought my problem will be solved if I format the pc to ubuntu 13.10 (was in 14.04 before)
pvr work ok in xbmc. not work at all in pseudotv live.
18:44:23 T:139693019015104 NOTICE: -----------------------------------------------------------------------
18:44:24 T:139693019015104 NOTICE: Starting XBMC (12.3 Git:9ed3e58), Platform: Linux (Ubuntu 13.10, 3.11.0-20-generic x86_64). Built on Dec 13 2013
18:44:24 T:139693019015104 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:44:24 T:139693019015104 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:44:24 T:139693019015104 NOTICE: special://masterprofile/ is mapped to: /home/salon/.xbmc/userdata
18:44:24 T:139693019015104 NOTICE: special://home/ is mapped to: /home/salon/.xbmc
18:44:24 T:139693019015104 NOTICE: special://temp/ is mapped to: /home/salon/.xbmc/temp
18:44:24 T:139693019015104 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:44:24 T:139693019015104 NOTICE: Local hostname: salon-Veriton-N280G
18:44:24 T:139693019015104 NOTICE: Log File is located: /home/salon/.xbmc/temp/xbmc.log
18:44:24 T:139693019015104 NOTICE: -----------------------------------------------------------------------
18:44:24 T:139693019015104 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
18:44:24 T:139693019015104 NOTICE: Found 1 Lists of Devices
18:44:24 T:139693019015104 NOTICE: Enumerated ALSA devices:
18:44:24 T:139693019015104 NOTICE: Device 1
18:44:24 T:139693019015104 NOTICE: m_deviceName : @
18:44:24 T:139693019015104 NOTICE: m_displayName : Default (HDA Intel ALC662 rev1 Analog)
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra:
18:44:24 T:139693019015104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:44:24 T:139693019015104 NOTICE: m_channels : FL,FR
18:44:24 T:139693019015104 NOTICE: m_sampleRates : 44100,48000,96000
18:44:24 T:139693019015104 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
18:44:24 T:139693019015104 NOTICE: Device 2
18:44:24 T:139693019015104 NOTICE: m_deviceName : @:CARD=Intel,DEV=0
18:44:24 T:139693019015104 NOTICE: m_displayName : HDA Intel
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra: ALC662 rev1 Analog
18:44:24 T:139693019015104 NOTICE: Device 3
18:44:24 T:139693019015104 NOTICE: m_deviceName : iec958:CARD=Intel,DEV=0
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra: ALC662 rev1 Digital S/PDIF
18:44:24 T:139693019015104 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:44:24 T:139693019015104 NOTICE: Device 4
18:44:24 T:139693019015104 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=0
18:44:24 T:139693019015104 NOTICE: m_displayName : HDA NVidia
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra: HDMI #0
18:44:24 T:139693019015104 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:44:24 T:139693019015104 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
18:44:24 T:139693019015104 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
18:44:24 T:139693019015104 NOTICE: Device 5
18:44:24 T:139693019015104 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=1
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra: DEL DELL 2408WFP on HDMI #1
18:44:24 T:139693019015104 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
18:44:24 T:139693019015104 NOTICE: Device 6
18:44:24 T:139693019015104 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=2
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra: HDMI #2
18:44:24 T:139693019015104 NOTICE: Device 7
18:44:24 T:139693019015104 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=3
18:44:24 T:139693019015104 NOTICE: m_displayNameExtra: HDMI #3
18:44:24 T:139693019015104 NOTICE: load settings...
18:44:24 T:139693019015104 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
18:44:24 T:139693019015104 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:44:24 T:139693019015104 NOTICE: loading special://masterprofile/guisettings.xml
18:44:24 T:139693019015104 NOTICE: Getting hardware information now...
18:44:24 T:139693019015104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:44:24 T:139693019015104 NOTICE: Loaded playercorefactory configuration
18:44:24 T:139693019015104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:44:24 T:139693019015104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:44:24 T:139693019015104 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:44:24 T:139693019015104 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:44:24 T:139693019015104 NOTICE: Default DVD Player: dvdplayer
18:44:24 T:139693019015104 NOTICE: Default Video Player: dvdplayer
18:44:24 T:139693019015104 NOTICE: Default Audio Player: paplayer
18:44:24 T:139693019015104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:44:24 T:139693019015104 NOTICE: Log level changed to 0
18:44:24 T:139693019015104 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:44:24 T:139692654118656 NOTICE: Thread CSoftAE start, auto delete: false
18:44:24 T:139693019015104 NOTICE: Running database version Addons15
18:44:24 T:139692697843456 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:44:25 T:139693019015104 NOTICE: Previous line repeats 1 times.
18:44:25 T:139693019015104 NOTICE: Setup SDL
18:44:25 T:139693019015104 NOTICE: Checking resolution 15
18:44:25 T:139693019015104 NOTICE: Using visual 0x6b
18:44:25 T:139693019015104 NOTICE: GL_VENDOR = NVIDIA Corporation
18:44:25 T:139693019015104 NOTICE: GL_RENDERER = ION/PCIe/SSE2
18:44:25 T:139693019015104 NOTICE: GL_VERSION = 3.3.0 NVIDIA 319.60
18:44:25 T:139693019015104 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
18:44:25 T:139693019015104 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 524288
18:44:25 T:139693019015104 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 524288
18:44:25 T:139693019015104 NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
18:44:25 T:139693019015104 NOTICE: Running database version Addons15
18:44:25 T:139693019015104 NOTICE: Running database version ViewModes4
18:44:25 T:139693019015104 NOTICE: Running database version Textures13
18:44:25 T:139693019015104 NOTICE: Running database version MyMusic32
18:44:25 T:139693019015104 NOTICE: Running database version MyVideos75
18:44:25 T:139693019015104 NOTICE: Running database version TV22
18:44:25 T:139693019015104 NOTICE: Running database version Epg7
18:44:25 T:139693019015104 NOTICE: start dvd mediatype detection
18:44:25 T:139693019015104 NOTICE: initializing playlistplayer
18:44:25 T:139693018064640 NOTICE: Thread CDetectDVDMedia start, auto delete: false
18:44:25 T:139693019015104 NOTICE: DONE initializing playlistplayer
18:44:26 T:139692385122048 NOTICE: Thread XBPyThread start, auto delete: false
18:44:26 T:139692376729344 NOTICE: Thread Jobworker start, auto delete: true
18:44:26 T:139692368336640 NOTICE: Thread XBPyThread start, auto delete: false
18:44:26 T:139693019015104 NOTICE: initialize done
18:44:26 T:139692359943936 NOTICE: Thread XBPyThread start, auto delete: false
18:44:26 T:139693019015104 NOTICE: Running the application...
18:44:26 T:139692385122048 NOTICE: -->Python Interpreter Initialized<--
18:44:26 T:139692359943936 NOTICE: -->Python Interpreter Initialized<--
18:44:26 T:139692368336640 NOTICE: -->Python Interpreter Initialized<--
18:44:26 T:139692055467776 NOTICE: Thread Jobworker start, auto delete: true
18:44:26 T:139693019015104 NOTICE: ES: Starting event server
18:44:26 T:139692047075072 NOTICE: Thread CEventServer start, auto delete: false
18:44:26 T:139692047075072 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:44:26 T:139692047075072 NOTICE: UDP: Listening on port 9777
18:44:26 T:139693019015104 NOTICE: starting zeroconf publishing
18:44:26 T:139692038682368 NOTICE: Thread CTCPServer start, auto delete: false
18:44:26 T:139692021896960 NOTICE: Thread Jobworker start, auto delete: true
18:44:27 T:139692013504256 NOTICE: Thread EPG updater start, auto delete: false
18:44:27 T:139692376729344 NOTICE: Start - EPG thread started
18:44:27 T:139692376729344 NOTICE: PVRManager - starting up
18:44:27 T:139691663816448 NOTICE: Thread PVR manager start, auto delete: false
18:44:27 T:139691655423744 NOTICE: Thread PVR add-on updater start, auto delete: false
18:44:27 T:139692359943936 NOTICE: StorageServer Module loaded RUN
18:44:27 T:139692359943936 NOTICE: StorageClient-2.5.4 Starting server
18:44:27 T:139692359943936 NOTICE: StorageServer-2.5.4 Storage Server starting /home/salon/.xbmc/temp/commoncache.db
18:44:27 T:139691655423744 NOTICE: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - connection opened to 'HTS Tvheadend 3.9.570~g5fbe7a7~saucy', protocol v12 (timeshift enabled)
18:44:27 T:139692368336640 NOTICE: Thread PVR GUI info updater start, auto delete: false
18:45:00 T:139692055467776 NOTICE: Thread Background Loader start, auto delete: false
18:45:00 T:139692055467776 NOTICE: Previous line repeats 1 times.
18:45:00 T:139692055467776 NOTICE: Thread Jobworker start, auto delete: true
18:45:01 T:139691632297728 NOTICE: Previous line repeats 3 times.
18:45:01 T:139691632297728 NOTICE: Thread XBPyThread start, auto delete: false
18:45:01 T:139691632297728 NOTICE: -->Python Interpreter Initialized<--
18:45:01 T:139691632297728 NOTICE: script.pseudotv.live PseudoTV Live /home/salon/.xbmc/addons/script.pseudotv.live-master 0.3.8
18:45:01 T:139691632297728 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
18:45:01 T:139691615512320 NOTICE: Thread XBPyThread start, auto delete: false
18:45:02 T:139691615512320 NOTICE: -->Python Interpreter Initialized<--
18:45:02 T:139691615512320 NOTICE: script.pseudotv.live PseudoTV Live /home/salon/.xbmc/addons/script.pseudotv.live-master 0.3.8
18:45:02 T:139691615512320 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
18:45:02 T:139691615512320 NOTICE: CommonFunctions-2.5.1
18:45:02 T:139691615512320 NOTICE: Donor Import
18:45:02 T:139691615512320 NOTICE: Previous line repeats 1 times.
18:45:02 T:139691615512320 NOTICE: Donor_Download Enabled
18:45:03 T:139691615512320 NOTICE: Requesting
18:45:03 T:139691615512320 NOTICE: http://www.google-analytics.com/__utm.gif?utmp=PTVL%2F593412389%2Fsome1%2F0.3.8%2FPTVL%2F&utmac=UA-45979766-1&utmwv=5.2.2d&utmcc=__utma%3D1.593412389.1.1.1.1%3B&utmn=3918822966
18:45:03 T:139691615512320 NOTICE: Pragma: no-cache
Expires: Wed, 19 Apr 2000 11:43:00 GMT
Last-Modified: Wed, 21 Jan 2004 19:51:30 GMT
X-Content-Type-Options: nosniff
Content-Type: image/gif
Date: Thu, 24 Apr 2014 07:56:24 GMT
Server: Golfe2
Content-Length: 35
Cache-Control: private, no-cache, no-cache=Set-Cookie, proxy-revalidate
Alternate-Protocol: 80:quic
Connection: close
18:45:03 T:139693019015104 NOTICE: DVDPlayer: Opening: pvr://channels/tv/All TV channels/0.pvr
18:45:03 T:139693019015104 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:45:03 T:139691032090368 NOTICE: Thread CDVDPlayer start, auto delete: false
18:45:03 T:139691032090368 NOTICE: Creating InputStream
18:45:03 T:139691032090368 ERROR: PVRFile - Open - channel not found with filename pvr://channels/tv/All TV channels/0.pvr
18:45:03 T:139691032090368 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All TV channels/0.pvr]
18:45:03 T:139691032090368 NOTICE: CDVDPlayer::OnExit()
18:45:03 T:139691032090368 NOTICE: CDVDPlayer::OnExit() deleting input stream
18:45:03 T:139693019015104 ERROR: Playlist Player: skipping unplayable item: 0, path [pvr://channels/tv/All TV channels/0.pvr]
18:45:03 T:139691615512320 ERROR: EXCEPTION: XBMC is not playing any media file
18:45:03 T:139691615512320 ERROR: Previous line repeats 1 times.
18:45:03 T:139691615512320 ERROR: script.pseudotv.live-TVOverlay: Exception during seek
18:45:03 T:139693019015104 NOTICE: CDVDPlayer::CloseFile()
18:45:03 T:139693019015104 NOTICE: DVDPlayer: waiting for threads to exit
18:45:03 T:139693019015104 NOTICE: DVDPlayer: finished waiting
18:45:03 T:139691615512320 ERROR: EXCEPTION: Non-Existent Control 509
18:45:03 T:139691615512320 ERROR: EXCEPTION: Non-Existent Control 514
18:45:03 T:139691615512320 ERROR: EXCEPTION: Non-Existent Control 510
18:45:03 T:139693019015104 ERROR: Texture manager unable to load file: /home/salon/.xbmc/addons/script.pseudotv.live-master/resources/skins/Default/images/NA.png
18:45:03 T:139693019015104 ERROR: Texture manager unable to load file: /home/salon/.xbmc/addons/script.pseudotv.live-master/resources/skins/PTVL/media/NA.png
18:45:03 T:139693019015104 ERROR: Texture manager unable to load file: /home/salon/.xbmc/userdata/addon_data/script.pseudotv.live/logos/Ch 10 LiveTV.png
18:45:10 T:139693019015104 ERROR: ClearBlock: Trying to clear non existent block /home/salon/.xbmc/addons/script.pseudotv.live-master
18:45:14 T:139693019015104 ERROR: Previous line repeats 1 times.
18:45:14 T:139693019015104 NOTICE: Storing total System Uptime
18:45:14 T:139693019015104 NOTICE: Saving settings
18:45:14 T:139693019015104 NOTICE: stop all
18:45:14 T:139693019015104 NOTICE: PVRManager - stopping
18:45:14 T:139693019015104 NOTICE: ES: Stopping event server
18:45:14 T:139693019015104 NOTICE: stopping zeroconf publishing
18:45:14 T:139692047075072 NOTICE: ES: UDP Event server stopped
18:45:14 T:139693019015104 NOTICE: stop dvd detect media
18:45:15 T:139693019015104 NOTICE: stop sap announcement listener
18:45:15 T:139693019015104 NOTICE: clean cached files!
18:45:15 T:139693019015104 NOTICE: unload skin
18:45:15 T:139692359943936 NOTICE: StorageServer-2.5.4 Closed down
18:45:15 T:139693019015104 NOTICE: stop python
18:45:20 T:139693019015104 ERROR: XBPyThread::stop - script /home/salon/.xbmc/addons/script.pseudotv.live-master/default.py didn't stop in 5 seconds - let's kill it
18:45:20 T:139693019015104 NOTICE: stopped
18:45:20 T:139693019015104 NOTICE: destroy
18:45:20 T:139693019015104 NOTICE: closing down remote control service
18:45:20 T:139693019015104 NOTICE: unload sections
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
18:45:20 T:139693019015104 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
18:45:20 T:139693019015104 NOTICE: application stopped...
please help me... I tried to change everything and the result is the same: changed tvheadend version, tried in xbmc 12.3 and 13 beta, tried in ubuntu 14.04 and now on 13.10.. I really dont know where is the problem..
thanks.
