(2014-05-05, 01:04)RockDawg Wrote: [ -> ]I tried to update and to the latest and I keep getting a Failed Script error. I followed the instructions for an upgrade but no luck. Here's the log:
http://xbmclogs.com/show.php?id=193547
"C:\Users\Kevin\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 38, in __init__
import CommonFunctions
ImportError: No module named CommonFunctions
you need to re-install simpledownloader script, looks like there is something wrong with it.
otherwise nothing seems to be wrong with PseudoTV Live
I don't understand why I don't get logos for channels with the exact same spelling. for Example HBO. I rename the channel to HBO. Pretty hard to mess that up.
(2014-05-05, 02:51)mrpcpro Wrote: [ -> ]I don't understand why I don't get logos for channels with the exact same spelling. for Example HBO. I rename the channel to HBO. Pretty hard to mess that up.
did you set the path for the logos in PTVL's settings? and selected EPG to use Logos, not text?
(2014-05-05, 02:59)Lunatixz Wrote: [ -> ] (2014-05-05, 02:51)mrpcpro Wrote: [ -> ]I don't understand why I don't get logos for channels with the exact same spelling. for Example HBO. I rename the channel to HBO. Pretty hard to mess that up.
That's exactly what I did. I downloaded logos from donors. The path looks correct. I checked spelling of logo and channel. Nothing. I will take screen shots
mrpcpro
(2014-05-05, 03:02)mrpcpro Wrote: [ -> ] (2014-05-05, 02:59)Lunatixz Wrote: [ -> ] (2014-05-05, 02:51)mrpcpro Wrote: [ -> ]I don't understand why I don't get logos for channels with the exact same spelling. for Example HBO. I rename the channel to HBO. Pretty hard to mess that up.
mrpcpro
I think I figured it out
mrpcpro
(2014-05-05, 03:20)Lunatixz Wrote: [ -> ]@mrpcpro what was wrong?
I had to change it to the ALT directory. Some of the logos weren't in the main directory. I'm not sure if pseudotv live looks in the other folders, but it didn't pick up the logos until I change it manually.
I think It might be a good idea to disable the logo while playing in live channels since most TV stations put their own logo in the show. They it comes up double
mrpcpro
(2014-05-05, 04:04)mrpcpro Wrote: [ -> ] (2014-05-05, 03:20)Lunatixz Wrote: [ -> ]@mrpcpro what was wrong?
mrpcpro
Logos in live channels should already be disabled. Are you seeing them?
(2014-05-05, 04:10)Lunatixz Wrote: [ -> ] (2014-05-05, 04:04)mrpcpro Wrote: [ -> ] (2014-05-05, 03:20)Lunatixz Wrote: [ -> ]@mrpcpro what was wrong?
mrpcpro
Yes. It's like seeing double lol
(2014-05-05, 04:23)mrpcpro Wrote: [ -> ] (2014-05-05, 04:10)Lunatixz Wrote: [ -> ] (2014-05-05, 04:04)mrpcpro Wrote: [ -> ]I had to change it to the ALT directory. Some of the logos weren't in the main directory. I'm not sure if pseudotv live looks in the other folders, but it didn't pick up the logos until I change it manually.
mrpcpro
I'll double checked code, it's disabled in livetv. Chtype 8 is livetv btw
(2014-05-05, 05:02)Lunatixz Wrote: [ -> ] (2014-05-05, 04:57)mrpcpro Wrote: [ -> ] (2014-05-05, 04:44)Lunatixz Wrote: [ -> ]I'll double checked code, it's disabled in livetv. Chtype 8 is livetv btw
https://onedrive.live.com/redir?resid=D3...oto%2c.png
R u sure its not chtype 9 your using?
https://github.com/Lunatixz/script.pseud...y.py#L1238
Code shows its disabled for chtype 8 which is livetv.
<setting id="Channel_2_type" value="8" />
<setting id="Channel_2_1" value="I98.28459048.microsoft.com" />
<setting id="Channel_2_2" value="hdhomerun://10369478-0/tuner0?channel=8vsb:587000000&program=1" />
<setting id="Channel_2_3" value="xmltv" />
<setting id="Channel_2_rulecount" value="1" />
<setting id="Channel_2_changed" value="False" />
<setting id="Channel_2_time" value="3008" />
<setting id="Channel_2_rule_1_id" value="1" />
<setting id="Channel_2_rule_1_opt_1" value="CBS" />
(2014-05-05, 05:09)mrpcpro Wrote: [ -> ] (2014-05-05, 05:02)Lunatixz Wrote: [ -> ] (2014-05-05, 04:57)mrpcpro Wrote: [ -> ]https://onedrive.live.com/redir?resid=D3...oto%2c.png
Weird... what skin r u using?
(2014-05-05, 05:11)Lunatixz Wrote: [ -> ] (2014-05-05, 05:09)mrpcpro Wrote: [ -> ] (2014-05-05, 05:02)Lunatixz Wrote: [ -> ]R u sure its not chtype 9 your using?
it is weird because what you are saying and what I'm showing are both true, and they shouldn't be. I'm using default skin
(2014-05-05, 05:13)mrpcpro Wrote: [ -> ] (2014-05-05, 05:11)Lunatixz Wrote: [ -> ] (2014-05-05, 05:09)mrpcpro Wrote: [ -> ]<setting id="Channel_2_type" value="8" />
I think I c why... ill fix problem later...
