2014-05-21, 19:18
(2014-05-21, 18:36)scilz Wrote: [ -> ](2014-05-21, 14:34)Lunatixz Wrote: [ -> ](2014-05-21, 05:06)pharmeceutikle Wrote: [ -> ]Did the last GIT UPDATE include the USTVNow fix? Because USTVNow is still broken for me.
What's broken? it works great for me...
(2014-05-21, 05:26)pharmeceutikle Wrote: [ -> ]Also, not very many of the recently added youtube channels are getting auto tuned. Has anybody else been noticing that?
I posted a few pages back that youtube auto tune is limited and random. Otherwise it will build every channel...
(2014-05-21, 06:19)scilz Wrote: [ -> ]2 channels of ustvnow work for me the other ones just have black screen and crash xbmc also some live strms work and some crash xbmc they all work in xbmc plugin/strm files but not in ptvl. i checked my log and it seems like the ones that are crashing are trying to seek ahead.
Have you tried changing from rtmp to rtsp in ustvnow settings I mentioned two weeks ago that ustvnow rtmp servers were having problems.
(2014-05-21, 07:29)pharmeceutikle Wrote: [ -> ]I can tell that's the case for USTVNow because I tune into a certain channel and it flashes "seeking" notification and then freezes. I then have to quit out of XBMC and restart.
In the latest git?? Because I pushed the fix already...
(2014-05-21, 12:17)EZ1976 Wrote: [ -> ]Hi
i just upgraded to Gotham to test PTVL with the latest build.
my settings consist of only
<settings>
<setting id="Channel_22_type" value="9" />
<setting id="Channel_22_1" value="5400" />
<setting id="Channel_22_2" value="http://192.168.1.1:9981/stream/channelid/18" />
<setting id="Channel_22_3" value="Channel 22" />
<setting id="Channel_22_4" value="Channel 22" />
<setting id="Channel_22_rulecount" value="1" />
<setting id="Channel_22_rule_1_id" value="1" />
<setting id="Channel_22_rule_1_opt_1" value="Channel 22" />
</settings>
the stream is a tvheadend server and it works in frodo and if i put it in a strm file (so i know the stream is ok)
once i start PTVL, it just says "no channels configured, would you like pseudotv live to auto tune channels"
once i go back to settings2.xml it is reset to default.
any ideas?
You might want to overriding stream check.
::Update::
Found the USTVnow problem, fix in next update...
if i try rtsp no ustvnow channels work with rtmp at least 2 do lol i sent you a log a few days ago.and it's not just ustvnow other strms that used to work in pstvl don't now but they still work in xbmc. from looking at the log and testing it seems the ones that no longer work are trying to seek ahead when played causing them to freeze some one else was having the same problem.
posting seek fix tonight
(2014-05-21, 18:45)EZ1976 Wrote: [ -> ](2014-05-21, 12:17)EZ1976 Wrote: [ -> ]Hi
<settings>
</settings>
any ideas?
now it works.
but the same settings that worked in frodo stream + EPG now freezes the plugin all together.
should i do anything special to get it to work with epg?
this is what i have in the settings2
<settings>
<setting id="Channel_22_type" value="8" />
<setting id="Channel_22_1" value="22" />
<setting id="Channel_22_3" value="xmltv" />
<setting id="Channel_22_changed" value="False" />
<setting id="Channel_22_time" value="32" />
</settings>
i have another frodo machine with the same exact file and it works there.
[/quote]
You're not sending any logs...
