Hi Luna
With the latest update V.0.5.1 , I told it to force reset the channels. Now it is stuck on channel 1 and not finishing adding the channel. It only does 50 entries so it doesnt take that long to parse the DB.
Kinda busy right now so i cant get any logs. Will upload them when i have time later tonight. Just putting this out there incase anyone is is having this issue, and knows how to fix it
Cheers!
BTW: Channel one is just a local HBO content, nothing special. Just HBO shows
Some errors from the logs:
19:39:23 T:139731920742144 NOTICE: SyncXMLTV
19:39:23 T:139731920742144 NOTICE: SyncUSTVnow
19:39:23 T:139731920742144 ERROR: EXCEPTION: Could not get AddonPtr given a script id of plugin.video.ustvnow.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a Version: 2.1.0 plugin.
19:39:23 T:139731920742144 NOTICE: SyncSSTV
19:39:23 T:139731920742144 ERROR: EXCEPTION: Could not get AddonPtr given a script id of plugin.video.mystreamstv.beta.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a Version: 2.1.0 plugin.
19:39:23 T:139731920742144 NOTICE: SyncFTV
19:39:23 T:139731920742144 ERROR: EXCEPTION: Could not get AddonPtr given a script id of plugin.video.F.T.V.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a Version: 2.1.0 plugin.
19:39:27 T:139731920742144 NOTICE: SyncXMLTV
19:39:27 T:139731920742144 NOTICE: SyncUSTVnow
19:39:27 T:139731920742144 ERROR: EXCEPTION: Could not get AddonPtr given a script id of plugin.video.ustvnow.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a Version: 2.1.0 plugin.
19:39:27 T:139731920742144 NOTICE: SyncSSTV
19:39:27 T:139731920742144 ERROR: EXCEPTION: Could not get AddonPtr given a script id of plugin.video.mystreamstv.beta.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a Version: 2.1.0 plugin.
(2014-10-01, 03:36)wyild1 Wrote: [ -> ]Hi Luna
Cheers!
