(2014-10-12, 04:53)lazyboy0172 Wrote: [ -> ] (2014-10-12, 03:59)Lunatixz Wrote: [ -> ] (2014-10-12, 03:28)lazyboy0172 Wrote: [ -> ]alright, after quite a bit of time waiting on .5.1 for an update that un-broke it, I finally jumped to dev today to test it out and get it working again.
First of all, this was incredibly painless. I was worried I'd lose everything, but I just copied the settings2 file to my desktop, installed the dev zip, and copied my settings2 back over and all my channels were there, but now they actually loaded!
great start.
Only issues I've had is USTVNow shows up as "listing unavailable" for all the epg, but the channels all work so that's good. first time I've tried it so I'm not sure if that's a problem on ustvnow or ptvl. Other issue is that the epg is very slow. Again, these are first impressions so it's tough to say if it's truly a problem or if it's early stutters from first couple runs. As I said though, the channel listing is very slow. Bringing up the guide is about the same time as stable, but pressing up/down or page up/page down is very slow, and requests stack so if I press up, think it didn't get it and press up again, it'll go up twice..eventually. This is on a windows pc, pretty powerful gaming machine I use as a htpc.
just wanted to give some feedback since you've been asking for feedback on the dev branch to update stable for a few days and I'd been sitting on the sidelines. Thanks so much for such a fantastic plugin. it's terrific
Let the cache build up.. EPG gets faster. For ustvnow did u enable xmltv service?
after some more testing, everything seems to be running perfectly now. xmltv service was enabled, but maybe didn't run the first time when I noticed it? Now that I've been in and out of xbmc and re-started ptvl a few times the epg is back up to the speed I remember and ustvnow stations are pulling in the correct info. And for what it's worth, ustvnow is also synced correctly with epg timing. I'm on eastern time.
Cool... Glad everything is working.
(2014-10-12, 04:36)Lunatixz Wrote: [ -> ] (2014-10-12, 04:21)Crispybishop Wrote: [ -> ] (2014-10-12, 04:17)Lunatixz Wrote: [ -> ]You can't atm
Technically not a video plugin. Under addons, go to "enabled addons" and then "PVR Clients" and it's listed there. So it is a PVR client still, but doesn't require the traditional TV backend.
(2014-10-12, 04:17)Lunatixz Wrote: [ -> ]You can't atm, I don't plan on adding support... Since it's redundant...
How is it redundant? Makes sense to be able to access Live TV channels in PTVL, no? You already support that function thru the "Find PVR backend" option anyway, right? And you support USTVNOW in PTVL also.
Its redundant because you can already configure PTVL to run IPTV links...
Didn't u configure IPTV? IPTV doesn't provide content like ustvnow. Its two different things.
Im scared of making a fool of myself, but how do you parse out an m3u playlist into their relevant channels? I ctrl+f'd "m3u" and couldn't find anything...
IPTV Channels Listing: [redacted]
IPTV EPG: [redacted]
(2014-10-12, 05:31)Crispybishop Wrote: [ -> ] (2014-10-12, 04:36)Lunatixz Wrote: [ -> ] (2014-10-12, 04:21)Crispybishop Wrote: [ -> ]Technically not a video plugin. Under addons, go to "enabled addons" and then "PVR Clients" and it's listed there. So it is a PVR client still, but doesn't require the traditional TV backend.
I would remove those links... they are all illegal... and not welcome in my thread
(2014-10-12, 05:50)Lunatixz Wrote: [ -> ] (2014-10-12, 05:31)Crispybishop Wrote: [ -> ] (2014-10-12, 04:36)Lunatixz Wrote: [ -> ]Its redundant because you can already configure PTVL to run IPTV links...
Didn't realize they were an issue. My apologies.
Still leaves the question on how to parse out an m3u playlist and its xmltv list.
(2014-10-12, 05:54)Crispybishop Wrote: [ -> ] (2014-10-12, 05:50)Lunatixz Wrote: [ -> ] (2014-10-12, 05:31)Crispybishop Wrote: [ -> ]Im scared of making a fool of myself, but how do you parse out an m3u playlist into their relevant channels? I ctrl+f'd "m3u" and couldn't find anything...
currently there isn't a converter... so there is no way except to manually do it.
(2014-10-11, 23:04)Lunatixz Wrote: [ -> ] (2014-10-11, 22:50)windsorguy1979 Wrote: [ -> ]Hey Luna,
Wondering if you can point me in the right direction on a bug I'm trying to fix. I've autotuned USTVNOW channels and the wrong channel id is being stuffed into settings2.xml for a few of the channels. The "wrong" id is a valid id for another channel and this particular id is assigned to multiple channels which makes the program lineup in the EPG appear to the be same for all of these channels.
I manually updated my settings2.xml with the correct IDs from ustvnow.xml thinking this would solve the issue, but as soon as I rebuilt the guide to correct the bad EPG, something overwrote my manual changes in settings2.xml and reverted the IDs back to the wrong one for the affected channels.
So, "I11207102.labs.zap2it.com" is the ID in question, that is assigned to only one channel in my ustvnow.xml file (USA network), but that ID is being assigned to multiple channels in settings2.xml. Make sense? Anyone else seeing this issue? Running latest stable release on Amazon FireTV and OSX. Seeing this on both platforms.
EDIT: I cleared cache, and manually deleted the cache folder in the addon_data folder but no luck. Lots of XBMC restarts in between as well.
switch to development branch under "misc" settings
(2014-10-11, 19:55)RayW1986 Wrote: [ -> ] (2014-10-11, 18:24)Lunatixz Wrote: [ -> ]Is your xmltv using UTC or local time ?
Also before we look into the xmltv being the problem. Have you tried force resetting the channel. This should put everything back in sync. If not its the xmltv time... Easy fix.
Done a force channel reset and still no change. Decided to delete my xmltv file and re-run WebGrab+ with nothing changed in the files, and now the guide tihnks it's Monday morning. Now, again, I just loaded the same .xml file into TV Guide and it loads correctly. For the life of me I can't figure this out.
EDIT: As I said before I'm using UTC.
2ND EDIT: Thinking on it, it's the same config that I sent you for WG+ the other day, Luna.
3RD EDIT: On further investigating I noticed that when I bring the info up on a channel that is playing, it shows the info for the correct show that is on at the time. However, the EPG remains to be out (now, somehow, I'm three hours behind the real EPG. It's like it's randomly choosing how off it wants to be).
run development build
(2014-10-11, 19:32)frederik84 Wrote: [ -> ]Says in first post u update ur dontaion list/logins fridays or monday, sent u small gift earlier this week and i want the Donor Exclusive Chtyp so bad, cant u please update your list ?
and keep up the good work...
I appreciate your support:
You sent the donation tuesday, please wait till monday... I'm only one guy! doing A LOT on his off time
No worries: I just didn't hear anything from you and you don't know how hard it is to wait for extra goodies especially a whole week .
I have enabled debugging in my settings but cant find the log file. I fear that my pstv is messed up somehow. Cause It refuses to add ustv-now even though it worked fine earlier. Where would the log file be located?
Only thing that works for me is a few addons, youtube, rss and local files. I would love to get the Playon integration. Does it work at this point? I can see in my channel configuration that Netflix gets generated but dosnt show up in the epg
, Also Super Fav works but kinda buggy I'm sure u are aware.?
What approach is best to get a fresh install of pstv ?
I have used pseudotv live for months without issues, and now it suddenly stopped working.
Tried everything but nothning worked so did a fresh install of xbmc, deleted everything and started fresh, still the same issue:
Quote:11:38:24 T:3416 NOTICE: script.pseudotv.live PseudoTV Live C:\Users\bram\AppData\Roaming\Kodi\addons\script.pseudotv.live-master 0.5.1
11:38:24 T:3416 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
11:38:24 T:3416 NOTICE: Common addon methods: Initializing addon.common version: 2.0.1
11:38:24 T:3416 NOTICE: script.pseudotv.live-ChannelList: Donor Import Failed, Disabling Donor Features
11:38:24 T:3416 NOTICE: metahandler: Initializing MetaHandlers version: 2.7.0
11:38:24 T:2440 NOTICE: Thread JobWorker start, auto delete: true
11:38:24 T:3416 NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.6
11:38:24 T:3416 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named CommonFunctions
File "C:\Users\bram\AppData\Roaming\Kodi\addons\script.pseudotv.live-master\service.py", line 8, in <module>
from resources.lib.EPGWindow import *
File "C:\Users\bram\AppData\Roaming\Kodi\addons\script.pseudotv.live-master\resources\lib\EPGWindow.py", line 31, in <module>
from PVRdownload import *
File "C:\Users\bram\AppData\Roaming\Kodi\addons\script.pseudotv.live-master\resources\lib\PVRdownload.py", line 6, in <module>
downloader = downloader.SimpleDownloader()
File "C:\Users\bram\AppData\Roaming\Kodi\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 38, in __init__
import CommonFunctions
ImportError: No module named CommonFunctions
Google didn't help me, can anyone help? thanks!
Bloob, looks like you are using helix which is not supported
LuNaTiX
Is it possible and not to much work to bring back the "color_chanbug" option in settings.xml ?
It worked fine in 0.4.8a
Thanks in advance
Roy
(2014-10-12, 17:57)jcaa6479 Wrote: [ -> ]@LuNaTiX
Thanks in advance
Roy
Its still there... Just renamed to use unaltered logo
(2014-10-12, 11:03)frederik84 Wrote: [ -> ] (2014-10-11, 23:04)Lunatixz Wrote: [ -> ] (2014-10-11, 22:50)windsorguy1979 Wrote: [ -> ]Hey Luna,
(2014-10-11, 19:55)RayW1986 Wrote: [ -> ]Done a force channel reset and still no change. Decided to delete my xmltv file and re-run WebGrab+ with nothing changed in the files, and now the guide tihnks it's Monday morning. Now, again, I just loaded the same .xml file into TV Guide and it loads correctly. For the life of me I can't figure this out.
PlayOn works great along with super fav.
EDIT: Removed Post per thread rules
(2014-10-12, 19:26)windsorguy1979 Wrote: [ -> ]Thanks to Luna for his support in a different forum, I've added a channel pointing to a genre in the). It's working great, just tweaking now. It's picking up the shows in order, and randomizing the episodes (added a Force Random rule), so since the Simpsons is the first show in the family genre, it's adding all of the Simpsons episodes before it'll add any of the other shows. My question... any way to not only randomize the episodes, but also randomize the shows so that I don't end up with all of the simpsons episodes on back to back to back to back ... . My current channel config is:
<setting id="Channel_66_type" value="15" />
<setting id="Channel_66_time" value="436" />
<setting id="Channel_66_1" value="" />
<setting id="Channel_66_2" value="" />
<setting id="Channel_66_3" value="25" />
<setting id="Channel_66_4" value="1" />
<setting id="Channel_66_rulecount" value="3" />
<setting id="Channel_66_rule_1_opt_1" value="Ororo Fam" />
<setting id="Channel_66_changed" value="False" />
<setting id="Channel_66_rule_2_id" value="10" />
<setting id="Channel_66_rule_3_id" value="16" />
<setting id="Channel_66_rule_3_opt_1" value="0" />
Please remove reference to banned plugins!
I can only wonder why you went from a post and reply at the hub to here!
(2014-10-12, 20:28)tromy Wrote: [ -> ]You can create different channels for each show you want from the same plugin and then interleave those channels,with whatever rule u want
(2014-10-12, 19:51)Crispybishop Wrote: [ -> ]It parses recursively from the top of the list until it's reached the max indicated. I, too, would love the option for it to randomize. Perhaps a setting of "find the first X results" followed by "randomize X shows within those results". But that may be hard for Luna to implement, and would make parsing take much longer. But if possible, I echo this request!
Doesn't show me much respect to ignore simple rules i've asked you to kindly follow... rules are in post 1...
If you want to discuss related feeds and plugins, go to the hub!
