(2014-11-14, 03:18)BankerBankson Wrote: [ -> ] (2014-11-14, 02:44)aftv fan Wrote: [ -> ]Does not work on android!! Period!! I have tried this for the last year on every update!every update its worst on android!
New acct 2 days old...lots of exclamation marks, non-constructive feedback....checks out to be xavier.ba
Don't feed the troll, just report these non-constructive criticisms. He was already banned once.
I believe you are correct... My first though was how it sounds like a Xavier post.
(2014-11-14, 03:36)Lunatixz Wrote: [ -> ] (2014-11-14, 03:18)BankerBankson Wrote: [ -> ] (2014-11-14, 02:44)aftv fan Wrote: [ -> ]Does not work on android!! Period!! I have tried this for the last year on every update!every update its worst on android!
I mean, if it walks like a troll and talks like a troll, it's probably that jackass.
(2014-11-14, 03:53)ARYEZ Wrote: [ -> ] (2014-11-14, 03:36)Lunatixz Wrote: [ -> ] (2014-11-14, 03:18)BankerBankson Wrote: [ -> ]New acct 2 days old...lots of exclamation marks, non-constructive feedback....checks out to be xavier.ba
I guess this is not an android compatible post! Sorry!
(2014-11-13, 22:34)Lunatixz Wrote: [ -> ]okay, sounds fine to me... i'll try and include it with tonights update...
Holy Crap! I just read the changelog on the new update. Thank you for all your hard work! This new update fixed my artwork issue as well. Im going to donate again. Have a drink on me!
can I have two xml tv files. one for usa and the other for Europe?
I have this in an m3u file but it's not autotuned. any ideas?
#EXTM3U
#EXTINF:210 tvg-id=S28.2E-2-2024-3817 tvg-logo=/logos/148.png,Sky Movies Sci-Fi Horror
http://cdn-07.v-sr.net/gpl/z050230/USERN...46?t=2&d=4
(2014-11-10, 00:21)BankerBankson Wrote: [ -> ]
Only problem I'm having now is the resolution logo & the channel logo overlapping. Don't think that was a change on my end...lemme know what to look for in case it likely is. Thanks!
I am having the same problem with the channel logo over the resolution logo im the ptvl skin after the latest master update to 0.56. I am running Gotham using Aeon MQ5. None of the other media flags are showing either. Just the resolution flag.
I also noticed that the info popup doesn't have the clear art on the right side like the view you show on the first page screenshots. Is this a setting or a change you made?
Other than this it is running great so far. Good work!
(2014-11-14, 07:45)mrpcpro Wrote: [ -> ]can I have two xml tv files. one for usa and the other for Europe?
#EXTM3U
you can have as many tv guide as you like. You just mention this in here for channel type 8:
Quote:<setting id="Channel_#_1" value="[YOUR CHANNEL NAME AS IT IS SHOWN IN XMLTV FILE]" />
<setting id="Channel_#_3" value="[YOUR XMLTV FILE WITHOUT EXTENTION]" />
See the first page for more details please
M3U8 file parsing is restrictive to donator only.
I am a donor and i will donate again to keep this project alive.
The reason I mention the XML is because pstvl ask for XML location and you can only choose one
Carlos
(2014-11-14, 10:43)alibaba011 Wrote: [ -> ] (2014-11-14, 07:45)mrpcpro Wrote: [ -> ]can I have two xml tv files. one for usa and the other for Europe?
#EXTM3U
(2014-11-14, 14:50)mrpcpro Wrote: [ -> ]I am a donor and i will donate again to keep this project alive.
Carlos
#EXTM3U
Try reactivating donor features then reboot xbmc. If that doesn't work please pm me the m3u list for testing.
This add-on is fantastic, thanks for all your hard work.
For anyone having trouble getting a TV Show channel to play its episodes in order, I found that creating a genre for that show and ticking the "Play shows in order" box in PseudoTV Manager works. For example, for Game of Thrones, I created a new genre called "Game of Thrones" and added the show to it. Then in stead of making a channel for a single show, a made a channel for the Game of Thrones genre I created. While I was never able to get the shows to play in order doing this with a single TV Show channel, doing this with a TV genre does seem to work.
PVTL seems to have issues reading certain video files--specifically videos ripped from YouTube. PVTL will load those shows but the episodes appear to last forever in the guide even if the show is only 20 minutes, and PVTL doesn't seem to be able to seek to the "current time" in these videos--they'll always play from the beginning. Once its already started, PTVL is able to skip and seek and sees the episode length correctly. I thought this was odd considering XBMC reads these files without a problem.
(2014-11-14, 15:19)nellie7878 Wrote: [ -> ]This add-on is fantastic, thanks for all your hard work.
You sure the YouTube videos aren't "stacked" using the hide short video setting?
(2014-11-14, 15:23)Lunatixz Wrote: [ -> ]You sure the YouTube videos aren't "stacked" using the hide short video setting?
They were ripped from YouTube and stored locally as TV Shows in .mp4 format and loaded into XBMC like any other show. They're not short videos, each is 10-30 minutes long.
EDIT: Oddly enough, if these YouTube rips are loaded in a channel as a directory instead of a normal show, the lengths seem to be fine.
(2014-11-14, 15:25)nellie7878 Wrote: [ -> ] (2014-11-14, 15:23)Lunatixz Wrote: [ -> ]You sure the YouTube videos aren't "stacked" using the hide short video setting?
force a channel rebuild, and please send me a debug log, read post1 on how to enable debugging and how to upload log, thanks
I don't think my request is possible, but I wanted to post to see if anyone had any ideas...
I want to create two channels that have the same shows. The only difference would be the language and subtitles. For example:
Channel 1 - Cowboy Bebop (Audio: Japanese / Subtitles: English)
Channel 2 - Cowboy Bebop (Audio: English / Subtitles: None)
Does anyone have any ideas how to do this without having two separate video files?
