(2015-01-07, 05:49)tommymsw Wrote: [ -> ]I would like to use the auto tuning feature to populate PTVL with streaming channels and then manually remove the ones I do not like or don;t work. But I can't seem to manually delete any channels after auto tune. If I delct a channel in channel configuration, the next screen comes up, but my only option is to back out. I can't select anything.
Try using the PTVL channel manager for Windows you can find it on page 1
Having problems with donor options...
Was emailed Username
assword....
I entered them in, no spaces, cap sensitive... click update and nothing happens... The donor options menu remains greyed out on Autotune.
Have tried exiting and returning multiple times... Anyone know why the options are not activating? Thanks
(2015-01-07, 09:22)capunk2441 Wrote: [ -> ]Having problems with donor options...
Was emailed Usernameassword....
At least you got a donor log in. I never received one after donating.
I know that in the guide you can set colors for different show types, etc, but is there a way to set a different color for each block of channels.
For example, my channels are set up in themed groups of 10 or 20. My tech shows are in the 80s. My music channels are the 90s. My sports channels are the 40s. I want to set it up so everything in each block gets colored the same regardless of what type or genre the content is. For example all the sports channels would be green. All the movie channels red, and all the tech channels orange.
Is this possible?
(2015-01-07, 04:47)ninjabucket Wrote: [ -> ]Still waiting on the spooler to finish, but the logs are showing this:
21:43:39 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork Cache Disabled
21:43:39 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork_NEW
21:43:39 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Chtype <= 7
21:43:39 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Infolder Artwork
21:43:39 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Infolder Artwork - Fallback
21:43:39 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Json Artwork
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Artwork Folder
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, setImage = C:\Users\Chip\AppData\Roaming\Kodi\userdata\addon_data\script.pseudotv.live\cache\artwork/272472-landscape.jpg
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork Cache Disabled
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork_NEW
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Chtype <= 7
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Infolder Artwork
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Infolder Artwork - Fallback
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Json Artwork
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, setImage = C:\Users\Chip\AppData\Roaming\Kodi\userdata\addon_data\script.pseudotv.live\cache\artwork/271659-landscape.jpg
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, Artwork Download
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: DownloadArt
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: DownloadArt, movie
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: DownloadArt, Fanart.TV
21:43:40 T:12080 NOTICE: script.pseudotv.live-fanarttv: get_image_list_Movie
21:43:40 T:12080 NOTICE: script.pseudotv.live-fanarttv: get_data
21:43:40 T:12080 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, setImage = C:\Users\Chip\AppData\Roaming\Kodi\userdata\addon_data\script.pseudotv.live\cache\artwork/tt1990314-landscape.jpg
Should that last front slash be a back slash? Checking the folder those images don't actually exist.
I am seeing the same thing doing a full debug:
09:04:51 T:59372 DEBUG: script.pseudotv.live-Artdownloader: FindArtwork, setImage = smb://DISKSTATION/video/Movies/1990's/1992/Honeymoon in Vegas (1992)\fanart.jpg
(2015-01-07, 04:30)amcfarla Wrote: [ -> ] (2015-01-06, 17:55)aptalca Wrote: [ -> ] (2015-01-05, 21:23)amcfarla Wrote: [ -> ]I noticed with the new PseudoTV live 0.5.7d, my fanart with the EPG guide and info screen (movie logos, poster, and fanart) will be working fine while building the channels with the background refresh set to on, but once the artwork spooling message shows up on the screen the artwork will default to the PseudoTV live logo instead of the artwork for any channel. This is happening on all my KODI machines with PseudoTV Live, as I am currently using the channel sharing option with all the devices with one master. Anyone have any suggestions on fixing this? Thank you.
While the spooling is going on, all images are disabled. Once the spooling ends (on the latest it is taking several minutes for me) images should be displayed again
No, not from what I am seeing
This is during the channel scan:
After the channel scan and the artwork spooling completes:
The Superman 2 logo is no longer present after it gets done scanning, and shows the default PseudoTV live logo. Started with the latest update.
Just to clarify, the following is what I observe:
1)During channel updating / background loading: Artwork is displayed (only tv shows, but that's a different issue)
2)When channel update is done and the artwork spooling starts: No artwork, just the PTVL logo
3)When artwork spooling is done (can take up to 30 min in my experience): Artwork is displayed (only for tv shows but that's a different issue)
Are you sure that when you took that last screenshot, artwork spooling was indeed completed and not just the channel building?
(2015-01-07, 08:33)Kalebbroo Wrote: [ -> ] (2015-01-07, 05:49)tommymsw Wrote: [ -> ]I would like to use the auto tuning feature to populate PTVL with streaming channels and then manually remove the ones I do not like or don;t work. But I can't seem to manually delete any channels after auto tune. If I delct a channel in channel configuration, the next screen comes up, but my only option is to back out. I can't select anything.
Thanks, the download link in Git is missing in the link. Not sure if it has to do with this: (Sorry about that, but we can't show files that are this big right now.). So maybe I just have to try again from time to time.
(2015-01-07, 19:29)tommymsw Wrote: [ -> ] (2015-01-07, 08:33)Kalebbroo Wrote: [ -> ] (2015-01-07, 05:49)tommymsw Wrote: [ -> ]I would like to use the auto tuning feature to populate PTVL with streaming channels and then manually remove the ones I do not like or don;t work. But I can't seem to manually delete any channels after auto tune. If I delct a channel in channel configuration, the next screen comes up, but my only option is to back out. I can't select anything.
Just click view raw and it will download.
(2013-07-14, 06:25)Lunatixz Wrote: [ -> ]LiveTV PVR (HDhomerun Prime) Autotune HOWTO * Courtesy of -bry
if anybody is having trouble generating strm files after they have setup dhcp reservation for their hdhomerun let me know. i setup something today that I would like to test and can generate strm files in about 2 seconds for you.
I am having trouble with autotune hanging when trying to add channels. I gets a few channels in and just hangs, and not at the same place either. I'm only using local movies on my NAS, so no streaming content. I tried uninstalling the addon, rebooting, and reinstalling it and just using the default settings. Nothing seems to keep it from hanging.
Are there any guides out there for setting up streaming channels? The autotune doesn't seem to grab any from my addons (other than Youtube). I am looking for how to manually add (via PTVL channel manager) either a single stream, or better yet, make a channel that consists of directory of an addon (i.e. the "documentaries" section of a particular addon.
I've been Googling to the bone but all the results just show you how to install PTVL anf maybe run the auto scan. I can't find any instructions on adding streams.
An update was pushed to my machine a couple of days ago.
It rebuilt all channels and seemed to force it to spool all artwork again... that's ok.
But the EPG is un-usably slow. Logs don't suggest anything wrong, just cannot browse EPG, can take 5-10 seconds to process a single "down" click to hightlight next channel.
Do I need to revisit any settings for the new build?
Hello to Everyone from Poland
I-m new user and have a question with adding channels from youtube i only add 1 channel ABC News and this channel populate to 4 channells i would have this channel only on channel 1 what is wrong with settings. Second : HD Documentaries channel dont show up dont know why : Please help :
<settings>
<setting id="Channel_1_type" value="10" />
<setting id="Channel_1_1" value="UCBi2mrWuNuyYy4gbM6fU18Q" />
<setting id="Channel_1_2" value="1" />
<setting id="Channel_1_3" value="100" />
<setting id="Channel_1_4" value="0" />
<setting id="Channel_1_changed" value="False" />
<setting id="Channel_1_rulecount" value="1" />
<setting id="Channel_1_rule_1_id" value="1" />
<setting id="Channel_1_rule_1_opt_1" value="ABC News" />
<setting id="LastExitTime" value="1420750927" />
<setting id="LastResetTime" value="1420751564" />
<setting id="Channel_1_time" value="1981" />
<setting id="Channel_2_type" value="10" />
<setting id="Channel_2_1" value="FullHDDocumentaries" />
<setting id="Channel_2_2" value="1" />
<setting id="Channel_2_3" value="50" />
<setting id="Channel_2_4" value="0" />
<setting id="Channel_2_changed" value="True" />
<setting id="Channel_2_rulecount" value="1" />
<setting id="Channel_2_rule_1_id" value="1" />
<setting id="Channel_2_rule_1_opt_1" value="HD Documentaries" />
</settings>
is anyone else having an issue with playon? My items weren't coming in correctly, so I tried going again from nothing...
here's my input. I wasn't sure what to do about the exclusions because it said not to have spaces so I dont, but didn't know if that was correct...anyway, here is what I have for these 2 channels, but for both channels all that is coming out is things from my netflix list, which is the first thing listed on playon so it's like it's just parsing the first 10 things it finds. Is my #_1 value not working correctly? what am I missing?
<setting id="Channel_33_type" value="16" />
<setting id="Channel_33_1" value="HGTV/Full Episodes" />
<setting id="Channel_33_2" value="BeachfrontBargainHunt,BrothervsBrother,BuyingandSelling,CaribbeanLife,CousinsUndercover,CurbAppeal,FixerUpper,FliporFlop,FlippingtheBlock,HawaiiLife,HGTVStar,TheJennieGarthProject,LivingAlaska,RehabAddict,VacationHouseforFree" />
<setting id="Channel_33_3" value="10" />
<setting id="Channel_33_4" value="1" />
<setting id="Channel_33_changed" value="True" />
<setting id="Channel_33_rulecount" value="1" />
<setting id="Channel_33_rule_1_id" value="1" />
<setting id="Channel_33_rule_1_opt_1" value="HGTV" />
<setting id="Channel_34_type" value="16" />
<setting id="Channel_34_1" value="Food Network/Full Episodes/Chopped" />
<setting id="Channel_34_2" value="" />
<setting id="Channel_34_3" value="10" />
<setting id="Channel_34_4" value="1" />
<setting id="Channel_34_changed" value="True" />
<setting id="Channel_34_rulecount" value="1" />
<setting id="Channel_34_rule_1_id" value="1" />
<setting id="Channel_34_rule_1_opt_1" value="Chopped" />
I've also tried "/HGTV/Full Episodes/" and "HGTV/FullEpisodes"...I'm just trying what I can think of and every time I just get the top directory which is netflix/mylist. where have I gone wrong?
(2015-01-08, 23:19)jarx34 Wrote: [ -> ]Hello to Everyone from Poland
<settings>
</settings>
FullHDDocumentaries isn't a youtube channel... the channel name is
TurkeyHolidayHotels
https://www.youtube.com/user/TurkeyHolidayHotels
