(2015-02-21, 18:48)amcfarla Wrote: [ -> ] (2015-02-21, 18:22)Indy_star Wrote: [ -> ]Sorry Luna, Directory Channels are still not working. Only first file repeated. Here is a fresh log
http://xbmclogs.com/pn44dk7u4
This one is strange for me, one machine it seems to work...yet another it is doing the same thing, one video
Did you by chance try to recreate the directory channel?
Yes I did, that debug log is 1 channel directory channel.
Try a force reset on the one working, see if it still works. It may be a certain file type but my directory channels did work in 0.5.8d
Thanks for the update Luna! I am just confirming the bug with EPG genre colours. When turned off the EPG works as intended. I am also not seeing any logos for my channels. I normally have "use unaltered channel bug" on. When I turn it off I do see the greyscale logos. Not sure if it something on my side.
Hey, is there a list anywhere of what is in the community lists? It would be a lot easier to see any "new" channels added without having to add a new channel and cycle through each option to see?
I know there is a path to a the lists on the main page, but the git lists are hard to read or not very easily explained.
Hello,
The new update seems to have messed up the autostart feature; it autostarts, runs for a minute or so, then it autostarts again while the video is playing.
Here's the log
http://xbmclogs.com/p1zhyjyx2
(2015-02-21, 20:11)Lunatixz Wrote: [ -> ]Fix in next update
Sry to be annoying about it but is the directory channel a confirmed problem as well or is it my setup?
(2015-02-21, 20:33)Indy_star Wrote: [ -> ] (2015-02-21, 20:11)Lunatixz Wrote: [ -> ]Fix in next update
No Problem, if its broken... its my bad... fix in next update.
Ever since update my addon crashed when trying to bring up onscreen guide. After it pops up the guide crashes and then the whole program goes down. Here is the error report I get.
Has anybody had a problem where when you exit PseudoTV, it's like Kodi is locked up but the debug log still shows keypresses?
(2015-02-21, 22:58)colin_clout Wrote: [ -> ]Ever since update my addon crashed when trying to bring up onscreen guide. After it pops up the guide crashes and then the whole program goes down. Here is the error report I get.
Ok so i disabled the epg and it seems to work fine now. Any insight?
(2015-02-22, 00:10)colin_clout Wrote: [ -> ]Ok so i disabled the epg and it seems to work fine now. Any insight?
you mean the epg genre color?
(2015-02-21, 18:55)Indy_star Wrote: [ -> ] (2015-02-21, 18:48)amcfarla Wrote: [ -> ] (2015-02-21, 18:22)Indy_star Wrote: [ -> ]Sorry Luna, Directory Channels are still not working. Only first file repeated. Here is a fresh log
I tried it again on the same machine that did work, and now I am only getting one video on a directory channel. So it seems to be still broken.
(2015-02-22, 00:00)wiz561 Wrote: [ -> ]Has anybody had a problem where when you exit PseudoTV, it's like Kodi is locked up but the debug log still shows keypresses?
I had this issue, but I pressed the x key (windows shortcut key for stop) and then it exited fully. Then I reloaded PSTVL and was able to exit it normally. It seems to only happen with streams, and not local media I'll post a log in bit.
