(2015-04-16, 20:27)Dumyat Wrote: [ -> ] (2015-04-16, 19:21)Chambers Wrote: [ -> ] (2015-04-16, 19:07)Dumyat Wrote: [ -> ]Not Sure if anybody is interested in any of these for their 'You Tube' Channels, but I created these channel logos for my own YT music video playlist channels a couple of days ago. Happy to share them on the community list if anybody wants to make use of them? Would just need to know how to get them on the list. They could probably do with resizing to a much smaller size.
Since, I have broad template made up in the same format, if anybody has any YT channel logo requests, just let me know. I can either create what your looking for, or send you my channel template:-
Can you post your settings2.xml for these channels too? I am interested in adding them to my channels as well
Hmmmm, there seems to be something very strange going on with my You Tube Plug-In. My playlists are not now playing in PTVL, but were definitely working last weekend when I created the channels, but they are also not playing now either when I'm using the YT plug-In directly outside of PTVL. I tried un-installing the YT plug-In to see if that would fix the problem if re-installed, but I got a dialog box pop up saying that PTVL and My Music depend on the YT plug-In to work and cannot therefore be un-installed/removed. So, I'm not going to remove 2 other Plug-In's as well, just to see if re-installing would fix the YT problem I'm having. If I message you the links for my YT playlists, do you want to try them yourself and see if they work in PTVL for you?
here you go 1 for YT channels and one for YT playlists, these are common and not restricted.... hope they help... I just edit the S2 directly adding the playlists or channels...
<setting id="Channel_224_type" value="10" />
<setting id="Channel_224_rulecount" value="2" />
<setting id="Channel_224_rule_1_id" value="1" />
<setting id="Channel_224_rule_1_opt_1" value="SumOrama" />
<setting id="Channel_224_1" value="PLlX_472jwzwyU9gubqh9Kks20dhRgjR6s" />
<setting id="Channel_224_2" value="Multi Playlist" />
<setting id="Channel_224_3" value="500" />
<setting id="Channel_224_4" value="1" />
<setting id="Channel_224_changed" value="False" />
<setting id="Channel_224_time" value="238817" />
<setting id="Channel_224_rule_2_id" value="16" />
<setting id="Channel_224_rule_2_opt_1" value="1" />
<setting id="Channel_224_rule_3_id" value="10" />
<setting id="LastResetTime" value="1429215075" />
<setting id="LastExitTime" value="1429054088" />
<setting id="Channel_2_type" value="10" />
<setting id="Channel_2_rulecount" value="1" />
<setting id="Channel_2_rule_1_id" value="1" />
<setting id="Channel_2_rule_1_opt_1" value="Sumo" />
<setting id="Channel_2_1" value="UCjEHJ_fQxC3wgXcIazGWt3Q" />
<setting id="Channel_2_2" value="Channel" />
<setting id="Channel_2_3" value="25" />
<setting id="Channel_2_4" value="0" />
<setting id="Channel_2_changed" value="False" />
<setting id="Channel_2_time" value="160987" />
Hi Luna,
I've been dealing with an issue for a while now where after installing PTVL it hangs Kodi when i try to close it. I've been dealing with it cause I feel like I've been asking a ton of questions but i'm hoping it might be an easy fix that others could benefit from too. Please see below my log file. After clicking exit it seems to take a good minute to actually close. Thank you
15:47:05 T:280 NOTICE: ===== PLEXBMC STOP =====
15:47:11 T:3344 NOTICE: Previous line repeats 1 times.
15:47:11 T:3344 NOTICE: Storing total System Uptime
15:47:11 T:3344 NOTICE: Saving settings
15:47:11 T:3344 NOTICE: stop all
15:47:11 T:3344 NOTICE: stop player
15:47:11 T:3344 NOTICE: ES: Stopping event server
15:47:11 T:3344 NOTICE: stopping upnp
15:47:11 T:3344 NOTICE: Webserver: Stopping...
15:47:11 T:3344 NOTICE: WebServer: Stopped the webserver
15:47:11 T:3344 NOTICE: Webserver: Stopped...
15:47:11 T:3632 NOTICE: ES: UDP Event server stopped
15:47:11 T:3344 NOTICE: stop sap announcement listener
15:47:11 T:3344 NOTICE: clean cached files!
15:47:11 T:3344 NOTICE: unload skin
15:47:16 T:3344 ERROR: CPythonInvoker(6, C:\Users\Kodi\AppData\Roaming\Kodi\addons\script.pseudotv.live\service.py): script didn't stop in 5 seconds - let's kill it
15:47:17 T:3596 WARNING: CPythonInvoker(3, C:\Users\Kodi\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py): the python script "C:\Users\Kodi\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class PythonBindings::XBMCAddon_xbmc_Player_Director
15:47:17 T:3612 NOTICE: StorageServer-2.5.4 Closed down
15:47:18 T:3604 NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
15:48:40 T:3344 NOTICE: stopped
15:48:40 T:3344 NOTICE: destroy
15:48:40 T:3344 NOTICE: closing down remote control service
15:48:40 T:3344 NOTICE: unload sections
15:48:40 T:3344 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:48:40 T:3344 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
15:48:40 T:3344 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
15:48:40 T:3344 NOTICE: application stopped...
Chambers
Post the issue with details and logs in the bugs thread:
http://forum.kodi.tv/showthread.php?tid=221352
There is less clutter there so Luna is more likely to see it. But make sure you include a full
debug log (wiki) so he can see what is going wrong. Luna usually doesn't like working with partial logs so you are better off uploading something to pastebin or xbmclogs.
Ihave used the Espan 3 and CBSnews add-on.
ABC NEWS 13
rtmp://ms-9.sbgnet.com/livenews/wloslive_medium
It works but it only plays during live broadcast
WYFF
http://54.162.135.248/server/play/hearst...c4cxO4D4wG
Same with this link
I like to find out how to get livestream.com to work with it.
I love this add- on thank for great job
Is there some kind of keymapping that can be done to skip back to the beginning of a program or ahead to the next one? Currently I just hit the chapter up/down button until I get there, but it would be nice if I could get to either with just a single button press.
(2015-04-19, 03:06)RockDawg Wrote: [ -> ]Is there some kind of keymapping that can be done to skip back to the beginning of a program or ahead to the next one? Currently I just hit the chapter up/down button until I get there, but it would be nice if I could get to either with just a single button press.
I use <,> on keyboard and it works fine
...way too many pages to go through…
...are the donor features still gone? Auto-tuning doesn't produce any extra channels beyond my local media as it used too… no YouTube or anything. Same thing with commercials/trailers and whatnot…
(2015-04-20, 07:46)ADHDMedia Wrote: [ -> ]...way too many pages to go through…
Have you tried reactivating?
I see turning off dynamic artwork can speed things up mentioned by users throughout the forums, yet I no longer find this setting available in new releases of PTVL. Can someone point me in the right direction please?
fr3qu3ncy If I remember correctly it is under Visual settings.
I would also consider setting EPG channels to Text instead of Logo if you are looking for a performance boost.
(2015-04-21, 20:56)azrael17 Wrote: [ -> ]@fr3qu3ncy If I remember correctly it is under Visual settings.
Can you tell me the exact name of this setting please? I'm not finding it. I remember seeing it in earlier versions but it's not available with latest PTVL.
(2015-04-21, 21:16)fr3qu3ncy Wrote: [ -> ] (2015-04-21, 20:56)azrael17 Wrote: [ -> ]@fr3qu3ncy If I remember correctly it is under Visual settings.
Looking now...I don't see the setting I remember, but under "Tweaks" there is one called "Find Missing GuideData (Art/Info)" which may be it.
Hi Luna, I provided you now my paypal e-mailadres and more information by pm about the donation I made by paypal. I hope you can find now the transaction. If you want more info please let me know.
