Autotuning youtube channels no longer works for me, all I get are local media channels. Neither the donor or community list works too, and when I try to add a youtube channel manually from the community list it says the list is empty or unavailable. Making a custom youtube pseudotv channel works just fine
Anyone have any idea what might be going on?
As of yesterday, my USTVNOW channels will not show EPG data. Is anybody else having this issue?
0.6.1c
The alert window that comes up letting you know that you need to disable Kodi's "Automatic audio and video playback" should probably say "Disable automatically
play next in list" for both audio and video. There is no option to turn off automatic playback that I'm aware of. Just a tiny wording thing that might cause some confusion.
Otherwise it looks good, I'll keep kicking the tires to see if I can break something
(2015-04-28, 23:02)Marshall Wrote: [ -> ]2) The alert window that comes up letting you know that you need to disable Kodi's "Automatic audio and video playback" should probably say "Disable automatically play next in list" for both audio and video. There is no option to turn off automatic playback that I'm aware of. Just a tiny wording thing that might cause some confusion.
With an emphasis on
both probably necessary. I had the video option already off as I do not want my videos playing one after another on me in case I doze off. Music on the other hand I kind of like having play entire albums for me... I sat there staring at the video playback option stupidly wondering why I kept seeing the pop up message until it finally hit me that by audio
and video playback it meant two different things...
I must be tired..
Also this should probably end up in the FAQ section sooner than later to save everyone some time, because you
know we're not going to be the only ones.
Glad to see an update, just waiting for everything to build and load...
Where are the settings to disable play next automatically? I have "play the next video automatically" unchecked under video playback. I'm still getting the window on launch.
(2015-04-29, 01:02)pc1975 Wrote: [ -> ]Where are the settings to disable play next automatically? I have "play the next video automatically" unchecked under video playback. I'm still getting the window on launch.
System/Music/Playback > uncheck "Play the next song automatically."
Hey could any of the other people having problems with youtube and other video plugins please answer a question for me? I too started developing issues with getting USATVNOW and couldn't figure out why. Then I noticed something in my current log--references to librtmp being missing. I went back and checked and sure enough it wasn't installed for me.
I have never to my knowledge installed these libraries so I can only assume they were usually pulled in automatically by the package manager (running my TV on Ubuntu-Mate these days) and I never noticed when they were autoremoved just as nicely... I should mention for clarity's sake that way back when I started with PTVL I checked and the libraries were installed already before I started to use it--I am aware they were a required change--I just never had to manually add them to my system via the package manager before.
So my question is: are most of us with issues in this regard missing the rtmp libraries? If so, have you fixed the issue by adding them back in at the appropriate places?
Could anyone tell me why we need to turn "Automatic audio and video playback" off?
I never had any problems with it in the past (even though I got the reminder to turn it off) but now it insists I turn it off and won't continue. However, I altered the script to ignore this setting and my updated PseudoTV Live seems to still run as I expect.
My kids like to watch some of their TV shows on continuous so it would be a real hassle to keep switching it on and off. I wondered if the issue was with features I possibly don't use? Checked the threads and couldn't really find anything.
Cheers in advance
(2015-04-29, 11:17)theslyfox Wrote: [ -> ]Could anyone tell me why we need to turn "Automatic audio and video playback" off?
Cheers in advance
I would like to know the answer to this as well.
custom skins are not loading the folder is no longer there after update
anyone else having same problem
THANK YOU, all my channel builds are going DEEP into ther aps now.! thanks you, befor they would add 3 or such , now they are attempting to go to the limits I set i.e. 250-500, No other things to report, once it rebuilt the channels all seems great.
Only problem still from previous is/are after inital launching I have to wait unitll the artspool completes or Ill get the channel info graphic stuck which needs a relaunch, in my case the time it takes for the art spool to complete is around 350 secs. so I launch get a drink and come back....
all in all Very greatful that the channels are digging deeper into my aps...
Thank you..
One question as to limits... If I set the master limits in settings to 200, will that overwrite the limit settings attached to indivual channels? I would like to set a master celing of 200 set under settings, and modify some channels to specific numbers...
Update: Seems the master limit will set channels that ARE NOT specificaly limited under its own channel limits....
(2015-04-29, 21:00)wrichards Wrote: [ -> ]THANK YOU, all my channel builds are going DEEP into ther aps now.! thanks you, befor they would add 3 or such , now they are attempting to go to the limits I set i.e. 250-500, No other things to report, once it rebuilt the channels all seems great.
Thank you..
OMG this is happening to you as well? I figured I was the only one since no one else was mentioning it, and it was probably something to do with having a fancy logo for each channel in the EPG, and having 100 or so channels of tons of local media that it was loading artwork for each time.
It does seem a little better with a default skin, but I really like Tromy's Titian and Nix skins, so sooner or later I'll get around to sending Luna some logs.
Regarding the custom skin location change in v6.1c copying the skin directory files - irrespective of the skin itself - to that location isnt being recognised upon PTV launch.
Haven't tried renaming custom skin folder back to custom to see if that will work but to restore Tromy's Nix skin to my setup I simply replaced the Comcast skin files with the Nix files and changed the skin selection.
