Is there a separate home to post problems with Donator Exclusive features?
I am not having much success with a few successfully operating under the Autotune section.
Or perhaps let me know which ones should be working so I can spend my time with those.
(2015-06-06, 21:39)bfarley68 Wrote: [ -> ]Is there a separate home to post problems with Donator Exclusive features?
Whats not working? btw I do not provide content, so if autotune channels are created, by do not work... thats not a bug, just a dead link...
(2015-06-06, 21:23)sickboyy Wrote: [ -> ] (2015-06-06, 21:21)Lunatixz Wrote: [ -> ] (2015-06-06, 21:15)sickboyy Wrote: [ -> ]Hmm I must be doing something wrong. I have a few YouTube channels and only one of them is working.
http://pastebin.com/GX0DSkVT (settings2.xml -- the YouTube playlists are at the bottom).
The 'Challenge' channel works fine but the others won't show up. I'm guessing it's because I'm grabbing usernames explicitly with the Challenge channel, whereas with the others I'm getting them from different places.
For playlists I'm grabbing the &list= part of a playlist and for channels I'm grabbing the ID which follows /channel/ on these pages.
I'm guessing that's wrong..?
YouTube channels work with channel Id ie uc..... Or by channel name, ie. vevouk
Playlists require playlist id ie Pl.....
Thanks for the help. The 'Discovery' channel (where the script is getting stuck) has a Multi Playlist with this value:
PLqt1BbpFEnLLoHMQTh7jBOvjmZE2soaj5|PLOIgvHgqep3Auswl_QFQvchQZAUmwqLDE
They're both prefixed with PL, so why would they not be accepted?
Just bumping this onto the new page
(2015-06-06, 21:55)sickboyy Wrote: [ -> ] (2015-06-06, 21:23)sickboyy Wrote: [ -> ] (2015-06-06, 21:21)Lunatixz Wrote: [ -> ]YouTube channels work with channel Id ie uc..... Or by channel name, ie. vevouk
I found a bug with youtube.... not sure if its related to the issues other users are having... but it fixes your issue with multichannels... i'll push the update tonight v.0.6.2c
Understood. I am trying to get the PseudoCinema experience to work. It tends to sit for a very long time when updating the channel where it says Please Wait...
This time I am not going to cancel out, so I guess my question is can this take a long time to build? (At the 20 minute mark now)
My media is on a network drive and my Kodi configuration uses MySQL for the video library. My network drive is being accessed, so I am assuming that it is loading my media from there?...
(2015-06-06, 21:57)Lunatixz Wrote: [ -> ] (2015-06-06, 21:55)sickboyy Wrote: [ -> ] (2015-06-06, 21:23)sickboyy Wrote: [ -> ]Thanks for the help. The 'Discovery' channel (where the script is getting stuck) has a Multi Playlist with this value:
Hopefully that will fix it. I don't see anything wrong with the YouTube content I'm trying to grab, they're both using either PL or UC.
<setting id="Channel_27_1" value="UC-9-kyTW8ZkZNDHQJ6FgpwQ" />
<setting id="Channel_25_1" value="PL5o3ll3G4acyuACDdy0HFjGN5y3o_rQBH|PL_jFbqOSEqaJs4l1clBJ2w8dRWArUcQH3" />
(2015-06-06, 20:19)Lunatixz Wrote: [ -> ] (2015-06-06, 20:15)RockDawg Wrote: [ -> ] (2015-06-04, 02:25)Lunatixz Wrote: [ -> ]Code:
[*] NEW! Start Over prompt when a show is 1/2 through show duration.
This is a great idea! When I tired it, it just made the video skip back whatever time the skip back is set to. It didn't go back to the beginning.
Also, I would suggest at least an option to enable this for any video that is not at the beginning and not just ones 50% or further in.
The video does skip back to the beginning... At least it should... and I'm happy with it a 50%, since this is just a reminder.
You can technically start over any show by simply clicking the skip back playlist button (if you have it mapped to a remote).
I just tried it about 20 times and it never skipped back to the beginning on any movie and less than half of the TV episodes I tried. Usually it just skips back a seemingly arbitrary amount of time. I've seen it anywhere from 2-30 minutes. But there was about 5 times it did go back to the beginning.
It's certainly your prerogative on how you implement a feature but I don't understand the logic behind why a user would want to skip back the beginning of a video that is half way or more through but not one that is say 25% of the way through.
Here is a video clip showing the skip back only going back 3:36:
(2015-06-06, 21:58)bfarley68 Wrote: [ -> ]Understood. I am trying to get the PseudoCinema experience to work. It tends to sit for a very long time when updating the channel where it says Please Wait...
Found a bug with PseudoCinema, will be fixed with tonight's update... has to do with youtube's recent api changes...
(2015-06-07, 00:35)RockDawg Wrote: [ -> ] (2015-06-06, 20:19)Lunatixz Wrote: [ -> ] (2015-06-06, 20:15)RockDawg Wrote: [ -> ]This is a great idea! When I tired it, it just made the video skip back whatever time the skip back is set to. It didn't go back to the beginning.
You need to understand.... code wise... it starts shows from the beginning...
https://github.com/Lunatixz/script.pseud...y.py#L2074
I don't know what kinda keymaps you have or what custom changes you've made to kodi... but by kodi's default it has no choice but to start over... look at the code for yourself... the action on start over is "action(SkipPrevious)" not skip some random time in the past... your issue may be unique to your setup.
If you want to give a suggested time that you prefer over 50% then let me know, but I personally don't want to see that prompt everytime I flip...
(2015-06-07, 00:54)Lunatixz Wrote: [ -> ] (2015-06-07, 00:35)RockDawg Wrote: [ -> ] (2015-06-06, 20:19)Lunatixz Wrote: [ -> ]The video does skip back to the beginning... At least it should... and I'm happy with it a 50%, since this is just a reminder.
I get what you're saying but I don't know what to tell you. I have no custom keymap.xml file. I am no coder so I have not made any changes to Kodi. Just some minor skin tweaks is all I'm capable of and I even switched back to Confluence (which I haven't modded at all) and it still does the same. About 40% of the time it skips back to the beginning the rest of the time it skips back a random amount. I mean all it is is hitting the select button, right? The select button works as expected everywhere else including all other areas of PTVL.
EDIT: I just tried it on my other Openelec machine and it acts the same way.
(2015-06-07, 01:09)RockDawg Wrote: [ -> ] (2015-06-07, 00:54)Lunatixz Wrote: [ -> ] (2015-06-07, 00:35)RockDawg Wrote: [ -> ]I just tried it about 20 times and it never skipped back to the beginning on any movie and less than half of the TV episodes I tried. Usually it just skips back a seemingly arbitrary amount of time. I've seen it anywhere from 2-30 minutes. But there was about 5 times it did go back to the beginning.
I wish I could help... maybe you should look into what happens when your try and use SkipPrevious outside of ptvl, does it do the same thing?
(2015-06-06, 22:05)sickboyy Wrote: [ -> ] (2015-06-06, 21:57)Lunatixz Wrote: [ -> ] (2015-06-06, 21:55)sickboyy Wrote: [ -> ]Just bumping this onto the new page
Just tried this again this morning (with the update) and I'm still getting the same problem. It gets to the channel 'Yesterday' and can't find any more.
http://pastebin.com/eJQiNFPW
Here's my log also:
http://pastebin.com/DATa9n4c
I must be doing something wrong but I can't see what? The 'Challenge' channel works fine.
(2015-06-07, 12:58)sickboyy Wrote: [ -> ] (2015-06-06, 22:05)sickboyy Wrote: [ -> ] (2015-06-06, 21:57)Lunatixz Wrote: [ -> ]I found a bug with youtube.... not sure if its related to the issues other users are having... but it fixes your issue with multichannels... i'll push the update tonight v.0.6.2c
Here's my log also: http://pastebin.com/DATa9n4c
Your log isn't a debug log, read op on how to correctly post a log.
(2015-06-07, 06:42)3CupsOfCoffee Wrote: [ -> ]@Lunatixz @RockDawg Chapters coded into the file, mkv or m4a?
Thanks, I'll look into it...
