(2015-06-06, 20:20)Lunatixz Wrote: [ -> ] (2015-06-06, 20:06)RockDawg Wrote: [ -> ] (2015-06-06, 16:37)snesmaster40 Wrote: [ -> ]Maybe the download is failing for some reason? The new version is 34mb so it'll take a bit longer than usual for PLTV to update/install. You could try downloading the zip file from:
https://github.com/Lunatixz/XBMC_Addons/...udotv.live
The dependency might be Youtube-dl as that's what gets installed with 0.6.2b
I ave the same problem on my Windows machine, but not my Openelec machines. I did try downloading the the 0.6.2b zip and it won't install because it says dependencies not met but 0.6.2a is running fine on it. . I have all the dependencies listed in the first post of the main thread for PTVL and I also have an addon called youtube-dl COntrol 15.318.0. I assume that's the same thing as you are talking about?
I placed youtube-dl as an optional dependency... should fix install issue
Could I be having an Andriod Kitkat only issue in that the 0.6.2b and 0.6.2c updates show as:
system > addons > get add-ons > Lunatixz Repo > Program Add-ons >
PseudoTV Live incompatible
I am using a Beelink R89 ARM device with XBMC Gotham 13.4-XBMC(0) 16DEC14.
I did not see any XBMC requirements, so I don't know if I'm supposed to upgrade XBMC for these updates to work.
I was working fine with PTVL 0.6.2a, but I cannot reload it due to the upgrade messages it gives upon execution. I am now at the point where I cannot cancel the request to upgrade and just use 0.6.2a as I was doing on Thursday of last week before I started getting upgrade messages.
Uninstall of PTVL 0.6.2a and re-install leaves me with a
System > Add-ons > Geet Add-ons > Lunatixz Repo > Program Add-ons >
PseudoTV Live Update available
Selecting the PseudoTV Live addon shows that it is version 0.6.2c and, then, displays the "missing dependencies" error upon execution. I f I go into the Add-on Information dialog and perform the update from the choices presented, therein, I get the same error. So, it seems I cannot get 0.6.2a that does not insist on an upgrade to 0.6.2b or c.
I have cleared-out all of PTVL up through uninstalling the Lunatixz Repository and re-installing with 0.6.2b, then clearing out and re-installing with 0.6.2c. No go. I still get a PTVL incompatible and the "missing dependencies" error message.
I am using the fusion site, but I have also tried to use Git Hub and have sneaker-netted the zip files from Git Hub onto a USB drive and into my R89. I cannot seem to use system > Add-ons > "install from zip file" without the "missing dependencis" error for either the
script.pseudotv.live-0.6.2b.zip
script.pseudotv.live-0.6.2c.zip
zip files on Git Hub and the
script.pseudotv.live-0.6.2a.zip
wants me to upgrade, then gives me the "missing dependencies" error or sits there as "incompatible"
Anyone out there successful in updating PTVL on an Android Kitkat device? How do I rollback to 0.6.2a without being pushed to upgrade? Is there a method of getting debug logs for the install attempt of any of these updates? I'd love to be able to provide something in order to get this situation remedied.
I look forward to any insight.
Cerafin
