(2013-11-02, 16:38)mzup Wrote: [ -> ]Just figured out what this is. I have a shortcut under Programs Submenu on home page for PTVL. After the last two updates it doesn't launch. If I click on Programs and then click on PTVL from the list it works. I removed the shortcut from Program submenu and put it back but still no work.
Just figured I let you know and if anyone else has seen this.
I have the same issue. I reset the shortcut from the home window and reselected PTVL, still doesn't work.
(2013-11-02, 17:00)Grbspltt Wrote: [ -> ] (2013-11-02, 16:38)mzup Wrote: [ -> ]Just figured out what this is. I have a shortcut under Programs Submenu on home page for PTVL. After the last two updates it doesn't launch. If I click on Programs and then click on PTVL from the list it works. I removed the shortcut from Program submenu and put it back but still no work.
Should be fixed now... let me know
any idea why the number keys on my remote are not working?
i have nothing set in keymap.xml and i use an original mce remote.
i would love to just hit the number keys (and if possible without the need to hit "enter")
thanks
(2013-11-02, 03:20)Grbspltt Wrote: [ -> ] (2013-11-01, 23:26)chris0147 Wrote: [ -> ]how do i install pseudo tv live and what files do i need to install in order i can watch the internet tv?
go to post 1 & 2...
You did not say which files i should download
(2013-11-02, 20:40)EZ1976 Wrote: [ -> ]any idea why the number keys on my remote are not working?
thanks
Nevermind, misunderstood the question before... I like pressing enter, keeps from miss entering a channel which happens from time to time.
I plan to add keypress options to the EPG during final build.
I'm having an issue that I saw a previous poster also had where my channel logos don't get found when using a custom set logo directory. They work fine using PTVL's default directory though. Is this something that has a solution and I missed it or do you need a log?
(2013-11-02, 22:09)Lunatixz Wrote: [ -> ] (2013-11-02, 20:40)EZ1976 Wrote: [ -> ]any idea why the number keys on my remote are not working?
thanks
thats ok but my issue that the number keys dont work at all.
in regular PTV i had no problem but here it seems that the number keys are ignored.
any ideas?
hi everyone.
am i the only one who cant access the advance configuration tab ?
i tried in the default skin but no success.
right now i copied it to the original PTV folder, edit it and put it back so it can work
(2013-11-03, 11:16)Lunatixz Wrote: [ -> ] (2013-11-03, 10:48)EZ1976 Wrote: [ -> ]hi everyone.
I'll check it out
Edit:: Fixed in master
damn you are fast
i like you better now
any idea why it takes a long time after i press "advance configuration" to get the window open?
btw the keyboard doesnt work when accessing a channel. i need to point with a mouse on the button and then i can select it.
just FYI
(2013-11-03, 12:31)EZ1976 Wrote: [ -> ] (2013-11-03, 11:16)Lunatixz Wrote: [ -> ] (2013-11-03, 10:48)EZ1976 Wrote: [ -> ]hi everyone.
I'll check it out
damn you are fast
just FYI
When accessing the channel from where? in advanced configuration?
As for slow load times, there are many factors...
(2013-11-03, 13:00)Lunatixz Wrote: [ -> ] (2013-11-03, 12:31)EZ1976 Wrote: [ -> ] (2013-11-03, 11:16)Lunatixz Wrote: [ -> ]I'll check it out
damn you are fast
just FYI
yes from the advanced configuration window.
as soon as i click (with mouse , again no keyboard here) it takes a good 30-60 seconds to open.
(2013-11-03, 13:56)EZ1976 Wrote: [ -> ] (2013-11-03, 13:00)Lunatixz Wrote: [ -> ] (2013-11-03, 12:31)EZ1976 Wrote: [ -> ]damn you are fast
just FYI
I don't know... Seems to be working fine on my end... lot's of things can cause PTVL to run sluggish... narrow down what's running in the background... look at your logs
