2013-07-15, 19:52
For some unknown reason, after a regular "Update Library", many of my TV shows (>80%) have duplicate entries for each episode. I believe this stems from an issue where my files are located at /var/media/hdd/Videos/, and there is a symbolic link from / called media/, such that:
are the same path.
Here's part of my userdata/sources.xml
I've tried "Clean Library", countless other tweaks, but I cannot seem to resolve the issue.
Whilst most TV shows are duplicated, some are correct, which only use the path /media/ (not /var/media/).
Any suggestions?
Note: I do not believe I can delete or rename the symbolic link due to the read only file system (OpenELEC)
are the same path.
<video>
<default pathversion="1"></default>
<source>
<name>TV</name>
<path pathversion="1">/var/media/hdd/Videos/TV</path>
</source>
<source>
<name>Film</name>
<path pathversion="1">/var/media/hdd/Videos/Film/</path>
</source>
</video>
Any suggestions?
