Hello
I couldn't find the thread which covers these topics so I apologies. I got the same bluray movie that has been converted and was thinking which is the best one to keep.
To the experts if you can please tell me.
1st movie :
Video : 1280*720 / 5779 | 4980 | 6035 kbps
Audio : English / AC3 5.1 | 640 kbps
2nd movie :
Video.....: AVC x264 1280x720 2200kbps 23.976fs
Audio.....: English 384kbps 48khZ 6channel AAC(LC)
3rd movie :
Video #0 : AVC at 1 812 Kbps
Aspect : 1904 x 1072 (1.776) at 23.976 fps
Audio #0 : AAC at 384 Kbps
Infos : 6 channels, 48.0 KHz
Audio #1 : AAC at 124 Kbps
Infos : 2 channels, 48.0 KHz
Thank you very much.
The first one has the highest bitrate and best sound.
Hello
Thanks for the reply on the post about which video/audio codec is best.
I was wondering isn't their a section where users could post about video codecs ? I've just received 500 + movies & have multiply copies and don't know which are the best. I can identify from the source 1080p, 720p but wanted more knowledge on it.
Anyways thanks
Well for a start you need to use a consistent tool to look at the files, your three examples above are all formatted differently and show slightly different info.
mediainfo is a well known and respected tool for investigating files. An example output:
nick@envy ~/Videos $ mediainfo The.Borgias.S03E08.720p.HDTV.x264.mkv
General
Unique ID : 126292693211635109721710059213979326175 (0x5F031684A2BBEE186FB8605AE07F16DF)
Complete name : The.Borgias.S03E08.720p.HDTV.x264.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.38 GiB
Duration : 53mn 35s
Overall bit rate : 3 697 Kbps
Encoded date : UTC 2013-05-27 16:53:55
Writing application : mkvmerge v6.0.0 ('Coming Up For Air') built on Jan 20 2013 10:28:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 53mn 35s
Bit rate : 3 240 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.147
Stream size : 1.21 GiB (88%)
Writing library : x264 core 132 r2310 76a5c3a
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 53mn 35s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 147 MiB (10%)
Default : Yes
Forced : No
Really if you want high quality video these days you are looking for
* h264 or VC1 video codec
* reasonable bitrate
* minimum 720p resolution
Also pay attention to the audio - a perfect video rip with a lousy stereo soundtrack might be a worse experience than slightly lower quality video with a great hifi surround audio track.
The ultimate test is how it looks to you.
