Full Version: RaspBMC & Pi
Hi
I have recently bought and configured my PI and last night installed the "Ace" skin to see if it was light enough for the PI. It works without fault and is very responsive. Very happy with it.
The only issue I found is that the specific RaspBMC settings are no longer available to me through any of the standard menus. I will take a further look tonight, to see if I can locate where they have gone.
Has anyone come across this before for this skin or am I doing something wrong?
It might be that the RaspBMC settings is a program addon and I need to look under that section, but is there anyway to configure this to show in the main menu?
Thanks in advance for any help
You can add video, music, programm addons to the menu. go to the settings submenu and select customize main menu and there you can add playlist, addon and so on the the main menu.
Thank You
