2013-07-18, 00:40
I graduated from the Raspberry Pi and now have a G-Box Midnight MX2. I was playing with some settings and don't know how to undo what I did. In the upper left hand corner I have a screen that pops up only during XBMC use. It displays CPU usage, and some other data, constantly updating.
On my tv it is hard to read, it shows (CPU) XBMC and a percentage after that, it also shows fps, the data keeps updating. I am pretty sure that I caused this playing withthe XBMC PROGRAMS from the main screen. The first line says "log data", and it also displays CPU ID.
Does anybody know how I can fix this? Or at worst case, can I reset the box to factory specifications? Any help is appreciated.
Thanks Mark
Edit:
I did the reset with the toothpick, and it boots up bot XBMC does not work. Do I need to do something else to make it work?
Thanks Mark
Edit:
