Full Version: Playback jumps/cuts post upgrade to 12.2
Hi
Upgraded to frodo 12.2 on mac mini osx and now video and audio jumps forward as if the stream is cut - skipping about 0.5 or 1 sec at a time.
Been trying to downgrade the Audio settings and they are now at:
HDMI Audio Output
2.0
Boost Volume on down mix
AC3 Capable
DTS Capable
HDMI Output Device
Video settings are now
Full Screen 1
1920x1080p
Playback settings are now
Auto Detect render method
Allow hardware VDADecoder
All rest OFF
All videos are off SMB share going through a BT Home Hub 4.
Been tinkering with the settings all evening and I can't seem to undo the jumps/skips on any video. Its pretty consistent.
Just wondering if I need to post a log file or am I missing a trick here and there is a fix I'm overlooking/missed.
All help greatly appreciated.Huh
Hi
I have uploaded a debug log file here - all help greatly appreciated please!
http://www.xbmclogs.com/show.php?id=38625
The skip did occur during the debug.
Huhbump?
I wish I knew what to say, but it's a bit above my head. Maybe one of the devs will have some insight.
Not a clue. Alot of strange audio device errors in there, but i think they are not related. Did you try without HW acceleration?
Hi
thanks for the review. I turned off HW acceleration and got aame results, log file here:
http://www.xbmclogs.com/show.php?id=39059
New settings used:
Display mode: full screen 1
Display: 1920x1080p
Vertical blank sync: always enabled
Audio output: Optical/Coax
Speaker config: 2.0
boost volume: yes
Audio output: HDMI
Render method: auto detect
(all other playback off except..Allowed error in aspect: none)
All help appreciated, really stuck with this.
Could you try to disable vertical blank sync for a test? (this could lead to tearing though).
Here you go - with vertical blank sync disabled:
http://www.xbmclogs.com/show.php?id=39310
Unfortunately the same jump in picture occurred, but less 'jerky' - noticable nonetheless
What are your audio settings in the audio-midi-setup application from osx?
Here are the audio-midi setup values:
HDMI
Output 48MHz 2ch-24bit Integer
Speakers:
Multichannel-stereo
BTW I've ruled out any network issues by having these files on the macmini and it still jumps.
Out of a need for pragmatism, where can I get a mac 12.1 download - alas i didnt archive the previous binary before overwriting with 12.1 my bad I know.
Thx
I downgraded to 12.0 - and everything is absolutely fine.
To help I've uploaded a log of the same actions so you can see no errors in 12.0 on same file, vs 12.2
http://www.xbmclogs.com/show.php?id=39739
I'm OK with 12.0 (had trouble with timeouts on 12.1 so will try that tomorrow).
