2016-03-30, 07:57
(2016-03-29, 08:11)OTinley Wrote: [ -> ]Quote:How can I get it? Will update be automatic?It should get updated.
Thanks. On kodi add-on was updated but what about Openelec? Will it be updated too?
(2016-03-30, 07:57)Mr Dan Wrote: [ -> ]If you have updates enabled then you should get the update. It's out already and the fixed add-on works.(2016-03-29, 08:11)OTinley Wrote: [ -> ]Quote:How can I get it? Will update be automatic?It should get updated.
(2016-04-13, 03:03)amcfarla Wrote: [ -> ]Is anyone else having troubles with the weather updating today? It has been sitting at 32 degrees all day long, and refreshing doesn't fix it.Yes. It died for me a few hours ago.
18:45:12 T:1838548096 DEBUG: weather.yahoo: version 3.1.1 started: ['/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/addons/weather.yahoo/default.py', '1']
18:45:12 T:1838548096 DEBUG: weather.yahoo: weather location: 9807
18:45:12 T:1838548096 DEBUG: weather.yahoo: forecast data: <?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<rss version="2.0" xmlns:yweather="http://xml.weather.yahoo.com/ns/rss/1.0" xmlns:geo="http://www.w3.org/2003/01/geo/wgs84_pos#">
<channel>
<title>Yahoo! Weather - Error</title>
<description>Yahoo! Weather Error</description>
<item><title>City not found</title><description>
Weather Data not Available at the moment
</description></item></channel></rss>
<!-- fan496.sports.gq1.yahoo.com Mon Apr 11 16:34:54 PDT 2016 -->
18:45:12 T:1838548096 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/addons/weather.yahoo/default.py", line 220, in <module>
forecast(location, locationid)
File "/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/addons/weather.yahoo/default.py", line 104, in forecast
properties(query,loc)
File "/storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/addons/weather.yahoo/default.py", line 145, in properties
set_property('Current.Condition' , condition[0].attributes['text'].value.replace('/', ' / '))
IndexError: list index out of range
(2016-04-13, 04:01)OTinley Wrote: [ -> ](2016-04-13, 03:03)amcfarla Wrote: [ -> ]Is anyone else having troubles with the weather updating today? It has been sitting at 32 degrees all day long, and refreshing doesn't fix it.Yes. It died for me a few hours ago.
Was using the updated version.
Ended up using the edited default.py here :
It works again if I don't rotate the location.
(2016-04-14, 22:41)gate1975mlm Wrote: [ -> ]I have a question why does extended forecast not work when yahoo offers a 10 day forecast?
https://www.yahoo.com/news/weather/unite...ia-2471217
(2016-04-15, 15:03)oksauce Wrote: [ -> ]with the newest version, everytime i start up, i get the script error.. have to reset location settings constantly, any advice?
thanks..
