Yes, thanks, but hurry...
I just walked outside into a rain storm without a coat on...
new version:
weather.yahoo-5.0.0.zip
it will be available as well through the kodi repo in a few hours.
please test and let me know if you have any issues (see first pos for the steps needed to create a debug log).
It's up and running again in Fairless Hills PA.
Thanks ronie
(2019-01-06, 23:00)Fergus Wrote: [ -> ]Appreciate ronie taking the time to look into this. Even more grateful that ronie also created the weatherbit.io Addon - I’ve switched over to it, and it works a treat!
What platform/s does weatherbit.io run on, how would one find it?
(2019-01-07, 03:09)ronie Wrote: [ -> ]new version: weather.yahoo-5.0.0.zip
Thank you ronie for the new version.
I have an issue with the new version.
The addon is not returning an error if I set Kodi's language to English.
It returns an error if I set it to my local language.
Tested in Leia RC4, this is the error.
NameError: global name 'KPHTOBFT' is not defined
The full debug log
https://paste.kodi.tv/powopetemo.kodi
ok, let's fix that error as well then :-)
please let me know is this version works correctly:
weather.yahoo-5.0.2.zip
(2019-01-07, 13:30)ronie Wrote: [ -> ]ok, let's fix that error as well then :-)
please let me know is this version works correctly: weather.yahoo-5.0.2.zip
Yes, you fixed it
It works perfectly now, thank you for the incredibly fast fix.
I've been trying the new updates, but the add-on still wouldn't update for my city in Japan. So in trying various things, I noticed my city was no longer in the list during searches in the add-on settings. I tried another city in Japan (Tokyo) and that works. I tried to search my city again, found it, and from then on the add-on worked OK with my city.
No issues here after update. thank you!
Are we supposed to manually d/l and install weather.yahoo-5.0.2.zip? I have auto update enabled in Yahoo weather. Nothing has updated after restarting KODI a few times. If I manually select update in KODI app, it only shows version 4.3.1 available to update which is the current installed version. Also going to KODI repo and selecting Yahoo weather only offers 4.3.1. What am I doing wrong? TIA.
Hmmm? Just auto updated to 5.0.0 and is working fine now. I don't think its been 20 minutes since last trying... Strange but thank you for applying new dev API keys and giving it to us.
#ronie Thank You For Update.
