2019-01-19, 00:21
Yes, last night I got Yahoo Weather app error message yet the forecast "seemed" correct. Failed on KODI 17.6 on an NVIDIA Shield and Raspberry PI.
(2019-01-08, 11:32)ronie Wrote: [ -> ](2019-01-08, 07:21)janiedjs Wrote: [ -> ]Have installed Yahoo Weather in Jarvis 16.1. All of a sudden it has not been working. Not giving any temperature info. Has a solid yellow line through it. Any suggestions?
(2019-01-08, 10:44)cadet Wrote: [ -> ]Hi,
My add-on 3.3.3 stop working 4, Jan. On Kodi 15.1
I have old IPAD on the wall and it's have great job. )
Can you help me ?
the current version of the yahoo weather addon will work on kodi 17 and kodi 18.
earlier kodi versions are no longer supported.
(2019-04-27, 05:06)blueribb Wrote: [ -> ]The Yahoo! Weather app just went out totally on all my devices. No readings at all. Let's just hope it's temporary.
Windows 10 desktop and (2) Intel NUC's running Libreelec 9.0.1
(2019-04-27, 17:07)mentat Wrote: [ -> ]Yes indeed... reverting (back) to urllib3 (1.24.1) restores add-on operation (don't forget to disable automatic updates in add-on settings).I don't see a way to revert back - at least on my Windows 10 install. Mine shows 1.25.1 with no options to go back.
Running Kodi 18.1 (Leia) with LibreELEC 9.0.1 (RPi2.arm) on RPi3 B+
(2019-04-27, 18:43)blueribb Wrote: [ -> ](2019-04-27, 17:07)mentat Wrote: [ -> ]Yes indeed... reverting (back) to urllib3 (1.24.1) restores add-on operation (don't forget to disable automatic updates in add-on settings).I don't see a way to revert back - at least on my Windows 10 install. Mine shows 1.25.1 with no options to go back.
(2019-04-27, 19:08)mentat Wrote: [ -> ](2019-04-27, 18:43)blueribb Wrote: [ -> ](2019-04-27, 17:07)mentat Wrote: [ -> ]Yes indeed... reverting (back) to urllib3 (1.24.1) restores add-on operation (don't forget to disable automatic updates in add-on settings).I don't see a way to revert back - at least on my Windows 10 install. Mine shows 1.25.1 with no options to go back.
You can download the last version of the add-on from here: https://mirrors.kodi.tv/addons/leia/scri...e.urllib3/
Then save or copy the zip file to a "source" defined in "File Manager" (Kodi Settings/System)
Then install the zip file using the "Install from zip file" option in "Add-ons" (Kodi Settings/System)
