Full Version: Yahoo! Weather
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
(2014-10-23, 11:29)a.rdet Wrote: [ -> ]¿Then for the present there is no solution?
correct.
It first worked when I tried it but now I get a script error:
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.UnicodeDecodeError'>
                                            Error Contents: 'ascii' codec can't decode byte 0xc3 in position 24: ordinal not in range(128)
                                              File "E:\Mes Documents\Mes vidéos\XBMC\portable_data\addons\weather.yahoo\default.py", line 29, in <module>
                                                __resource__   = xbmc.translatePath( os.path.join( __cwd__, 'resources', 'lib' ).encode("utf-8") ).decode("utf-8")
                                            UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 24: ordinal not in range(128)
My language and region is from France, I assume it's relative to that...?
Full log here.
My config:
  • win 8.1 x64
  • XBMC 13.2
  • yahoo weather 2.0.3
No matter the skin…
(2014-10-28, 22:13)fred_gaou Wrote: [ -> ]It first worked when I tried it but now I get a script error:
thx for the report!
i've pushed a fix to the addon repo.
I confirm the v3.0.1 fix the issue.
Have a problem on v3.0.1 running in Helix B1
When displaying the daily forecast panel in default confluence, the display is by day as follows:
Nov 05/06/07/08/09/10/11/12/13/14/15/16/17/08
The problem is the last day forecast is Nov 08 when I guess it should be Nov 18, or maybe it shouldn't be shown at all.
scott s.
(2014-11-05, 23:37)scott967 Wrote: [ -> ]Have a problem on v3.0.1 running in Helix B1
scott s.
yup, fixed it earlier today:
https://github.com/xbmc/xbmc/commit/aff8...034dd69b04
Working with v3.0.3 in Helix B1 and my city is getting a script failed, if I change it to another city it works. My city is Braga, Portugal.
(2014-12-02, 00:07)Morcegolas Wrote: [ -> ]Working with v3.0.3 in Helix B1 and my city is getting a script failed, if I change it to another city it works. My city is Braga, Portugal.
i just tried it and it works fine for me.
please post a Debug Log of the script error.
I can get the current weather in helix rc2 (Windows) but none of the forecast works, or the map. I will post a log later today.
(2014-12-05, 20:31)JPad Wrote: [ -> ]I can get the current weather in helix rc2 (Windows) but none of the forecast works, or the map. I will post a log later today.
yahoo weather does not provide any maps, nor extended weather info.
only a basic 5 day forecast will be available if you use this addon.
you're probably looking for openweathermap extended:
207110 (thread)
@ronie, Thank you! I appreciate the guidance. I'll give the other add-on a go! I guess I would have never have thought it didn't support it since the menu items where there to select it....
Is it possible to change the translated strings? I see "Partly Cloudy" translated wrong in hebrew and I'd like to change it.
(2014-12-11, 19:30)ofek Wrote: [ -> ]Is it possible to change the translated strings? I see "Partly Cloudy" translated wrong in hebrew and I'd like to change it.
translations are handled by Kodi, not the addon.
see strings 371 & 374 of the Kodi language file.
for more info: 141158 (thread)
Oh, I see... well I guess its not as easy to fix as I thought... they translated it word by word and in hebrew you need to change the order of the words ><
Received the following error on XBMC 13.2 with Yahoo Weather 2.0.4
00:20:18 T:4808   DEBUG: weather.yahoo: forecast data: <?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
                                                    <rss version="2.0" xmlns:yweather="http://xml.weather.yahoo.com/ns/rss/1.0" xmlns:geo="http://www.w3.org/2003/01/geo/wgs84_pos#">
                                                        <channel>
                                            <title>Yahoo! Weather - xxxxxxxxxxxxxxxxxxxxxxxx</title>
                                            <link>xxxxxxxxxxxxxxxxxxxxxxxxxxx</link>
                                            <description>Yahoo! Weather for xxxxxxxxxxxxxxxx</description>
                                            <language>en-us</language>
                                            <lastBuildDate>xxxxxxxxxxxxxxxxxxx</lastBuildDate>
                                            <ttl>60</ttl>
                                            <yweather:location city="xxxxxxxxxxxxx" region="xxxxxxxxxx"   country="United States"/>
                                            <yweather:units temperature="C" distance="km" pressure="mb" speed="km/h"/>
                                            <yweather:wind chill="12"   direction="40"   speed="4.83" />
                                            <yweather:atmosphere humidity=""  visibility="16.09"  pressure="982.05"  rising="0" />
                                            <yweather:astronomy sunrise="7:13 am"   sunset="4:52 pm"/>
                                            <image>
                                            <title>Yahoo! Weather</title>
                                            <width>142</width>
                                            <height>18</height>
                                            <link>http://weather.yahoo.com</link>
                                            <url>http://l.yimg.com/a/i/brand/purplelogo//uh/us/news-wea.gif</url>
                                            </image>
                                            <item>
                                            <title>xxxxxxxxxxxxxxxxxxxxxxxxxxxx</title>
                                            <geo:lat>36.98</geo:lat>
                                            <geo:long>-122.03</geo:long>
                                            <link>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</link>
                                            <pubDate>xxxxxxxxxxxxxxxxxxxxxxxxx</pubDate>
                                            <yweather:condition  text="Cloudy"  code="26"  temp="12"  date="xxxxxxxxxxxxxxxxxxxxxx" />
                                            <description><![CDATA[
                                            <img src="http://l.yimg.com/a/i/us/we/52/26.gif"/><br />
                                            <b>Current Conditions:</b><br />
                                            Cloudy, 12 C<BR />
                                            <BR /><b>Forecast:</b><BR />
                                            Mon - Showers. High: 13 Low: 9<br />
                                            Tue - Heavy Rain. High: 14 Low: 9<br />
                                            Wed - Showers. High: 14 Low: 8<br />
                                            Thu - Partly Cloudy. High: 14 Low: 9<br />
                                            Fri - Showers. High: 15 Low: 10<br />
                                            <br />
                                            <a href="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</a><BR/><BR/>
                                            (provided by <a href="http://www.weather.com" >The Weather Channel</a>)<br/>
                                            ]]></description>
                                            <yweather:forecast day="Mon" date="15 Dec 2014" low="9" high="13" text="Showers" code="11" />
                                            <yweather:forecast day="Tue" date="16 Dec 2014" low="9" high="14" text="Heavy Rain" code="40" />
                                            <yweather:forecast day="Wed" date="17 Dec 2014" low="8" high="14" text="Showers" code="11" />
                                            <yweather:forecast day="Thu" date="18 Dec 2014" low="9" high="14" text="Partly Cloudy" code="30" />
                                            <yweather:forecast day="Fri" date="19 Dec 2014" low="10" high="15" text="Showers" code="11" />
                                            <guid isPermaLink="false">xxxxxxxxxxxxxxxxxxxxxxxxxxxxx</guid>
                                            </item>
                                            </channel>
                                            </rss>
                                            <!-- fe468.global.media.gq1.yahoo.com xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -->
00:20:18 T:4808   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.ValueError'>
                                            Error Contents: invalid literal for int() with base 10: ''
                                              File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\weather.yahoo\default.py", line 212, in <module>
                                                forecast(location, locationid)
                                              File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\weather.yahoo\default.py", line 120, in forecast
                                                properties(query,loc)
                                              File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\weather.yahoo\default.py", line 170, in properties
                                                set_property('Current.DewPoint'      , dewpoint(int(condition[0].attributes['temp'].value), int(atmosphere[0].attributes['humidity'].value)))
                                            ValueError: invalid literal for int() with base 10: ''
Looks like the humidity value didn't get passed by Yahoo? Weird.
