2015-02-16, 19:12
2015-03-03, 08:07
anyone know the location of the file needed to be edited in OSX? I would like to have the weather correctly displayed.
2015-04-06, 16:48
I recently updated to OpenELEC 5.0.8 which is Kodi 14.2 and the Yahoo Weather add-on started to fail with a script error. I'm located in Edmonton, AB Canada. Here is the entry from the log file:
15:28:20 T:139691705747200 NOTICE: -->Python Interpreter Initialized<--
15:28:20 T:139691705747200 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: invalid literal for int() with base 10: ''
File "/storage/.kodi/addons/weather.yahoo/default.py", line 218, in <module>
forecast(location, locationid)
File "/storage/.kodi/addons/weather.yahoo/default.py", line 105, in forecast
properties(query,loc)
File "/storage/.kodi/addons/weather.yahoo/default.py", line 161, in properties
set_property('Current.DewPoint' , dewpoint(int(condition[0].attributes['temp'].value), int(atmosphere[0].attributes['humidity'].value)))
ValueError: invalid literal for int() with base 10: ''
Any ideas? My WOEID is correct in the settings.xml...
Thanks,
Paul
Thanks,
Paul
2015-04-06, 17:26
(2015-04-06, 16:48)pgordash Wrote: [ -> ]I recently updated to OpenELEC 5.0.8 which is Kodi 14.2 and the Yahoo Weather add-on started to fail with a script error. I'm located in Edmonton, AB Canada. Here is the entry from the log file:
Thanks,
Paul
That is why I will be sticking to Kodi 14.1 which works.
2015-04-06, 20:37
thanx, it will be fixed in v3.0.6 of the yahoo weather addon.
2015-04-07, 17:36
Ronie, the new update works great. Appreciate the quick fix.
Thanks,
Paul
Thanks,
Paul
2015-04-10, 07:50
using xbmc 13.2 and this add-on will not install from repository I get the following in log...
01:49:17 T:4696 NOTICE: Thread BackgroundLoader start, auto delete: false
01:49:50 T:3504 NOTICE: Thread JobWorker start, auto delete: true
01:49:52 T:3504 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
01:49:52 T:3504 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
01:49:52 T:3504 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:49:52 T:3244 NOTICE: Thread BackgroundLoader start, auto delete: false
01:49:53 T:2500 NOTICE: Thread JobWorker start, auto delete: true
2015-04-10, 16:04
(2015-04-10, 07:50)JasonMI Wrote: [ -> ]using xbmc 13.2 and this add-on will not install from repository
no idea..
try of you can get the zip from here:
http://mirrors.kodi.tv/addons/gotham/weather.yahoo/
2015-04-13, 05:39
thank you I was able to get it from a third party and install via zip
2015-05-10, 05:17
(2015-04-10, 16:04)ronie Wrote: [ -> ](2015-04-10, 07:50)JasonMI Wrote: [ -> ]using xbmc 13.2 and this add-on will not install from repository
no idea..
2015-06-16, 00:55
I suddenly started getting wildly wrong current temps. The forecast is all correct, the current conditions are all correct, but the temp/feels-like/dewpoint are all wrong.
It currently says it is 41 degrees here, and it is actually 81.
2015-06-16, 07:47
(2015-06-16, 00:55)JackQT Wrote: [ -> ]I suddenly started getting wildly wrong current temps. The forecast is all correct, the current conditions are all correct, but the temp/feels-like/dewpoint are all wrong.
please provide a Debug Log.
also check if temps are correctly listed for your location here: https://weather.yahoo.com/
2015-06-17, 02:54
Yeah. . .yahoo.com shows the wrong thing too.
Changed the zip to a town a few miles down the road and it works fine. Oh well. . .sorry for the trouble.
2015-07-14, 20:03
Script failed. Yahoo weather appears to be broken.
2015-07-14, 21:35
