I created a srtm file
http://www.archive.org/download/HalfLife2_13657/HalfLife2_13657_HQ.avi
http://www.archive.org/download/HalfLife2_13657/HalfLife2_13657_IQ.avi
http://www.archive.org/download/2011-03-05-SDA_Speed_Runs/HalfLife2EpisodeOne_hard_3713_HQ.mp4
Only first of them is being played.
Windows XP.
STRM files only work one URL per STRM file.
No, a file with multiple urls is displayed as a directory. And the links cannot be played even if 1 link per file.
As always, post a debug log showing you trying to play one of those streams.
Have you tried opening them by yourself?
00:13:02 T:3844 NOTICE: Thread Jobworker start, auto delete: true
00:13:10 T:3424 NOTICE: DVDPlayer: Opening: http://www.archive.org/download/HalfLife2_13657/HalfLife2_13657_IQ.avi
00:13:10 T:3424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
00:13:10 T:1928 NOTICE: Thread CDVDPlayer start, auto delete: false
00:13:10 T:1928 NOTICE: Creating InputStream
00:13:11 T:1928 NOTICE: Creating Demuxer
00:13:11 T:2424 NOTICE: Thread CFileCache start, auto delete: false
00:13:41 T:1928 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file http://www.archive.org/download/HalfLife2_13657/HalfLife2_13657_IQ.avi
00:13:41 T:1928 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
00:13:41 T:1928 NOTICE: CDVDPlayer::OnExit()
00:13:41 T:1928 NOTICE: CDVDPlayer::OnExit() deleting input stream
00:13:42 T:3424 ERROR: Playlist Player: skipping unplayable item: 0, path [http://www.archive.org/download/HalfLife2_13657/HalfLife2_13657_IQ.avi]
00:13:42 T:3424 NOTICE: CDVDPlayer::CloseFile()
00:13:42 T:3424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
00:13:42 T:3424 NOTICE: DVDPlayer: waiting for threads to exit
00:13:42 T:3424 NOTICE: DVDPlayer: finished waiting
00:13:44 T:2612 NOTICE: Thread Jobworker start, auto delete: true
00:13:44 T:3280 NOTICE: Thread Background Loader start, auto delete: false
00:13:44 T:3116 NOTICE: Thread Jobworker start, auto delete: true
That's not a
debug log (wiki) and it's only a snippet. Please upload your
entire debug log (wiki) to a public paste site such as
www.xbmclogs.com and post just the assigned URL here. Finally, please do not bump your own thread in less than a 24 hour period.
See
forum_rules (wiki) 1.3.6 and 1.1.6, respectively.
@ololoe: I just tried to play one in VLC, it didn't work. Some files just can't be streamed without downloading the whole thing first, I've seen it happen elsewhere. I don't know if the problem lies in ffmpeg or the web server.
negge VLC doesn't play or buffer too long even the first file, so it isn't a good comparison.
So can someone tell what's wrong with that files?
artrafael you have the urls - you don't need logs, unless the program behave different.
@ololoe: if VLC can't play them, chances are very high XBMC can't either since they both use the same codecs. Since those files are just plain AVI files, why don't you just download them?
We're not your gofers. If you want help then generate a log file for us to look at.
negge I meant VLC doesn't play it from internet. It have to play it from local drive but I haven't checked it.
ned Scott what's the problem of opening that links? My log can contain some private information I don't want to share. You won't see goatse if you open them, don't worry.
(2013-07-22, 02:29)ololoe Wrote: [ -> ]@negge I meant VLC doesn't play it from internet.
Exactly the point negge was making. If it won't stream for VLC, chances are it won't stream for XBMC either.
Quote:It have to play it from local drive but I haven't checked it.
Which is the second point negge suggested you do.
Quote:@ned Scott what's the problem of opening that links? My log can contain some private information I don't want to share. You won't see goatse if you open them, don't worry.
You can always edit your log to remove sensitive information before uploading it.
(2013-07-21, 23:35)ololoe Wrote: [ -> ]@negge VLC doesn't play or buffer too long even the first file, so it isn't a good comparison.
@artrafael you have the urls - you don't need logs, unless the program behave different.
Ololoe you are rude beyond belief. If you can't be bothered uploasding your logs, I don't know why you expect help.
FYI the first two play OK for me (although there is quitre a delay before it starts to play, it is NOT downloading the whole file first though), the last doesn't work at all for me.
