2013-07-21, 12:40
Hello!
I am new here. The last two weekends I played a lot with my new htpc machine.
Right now, after some time consuming frustrated efforts, I don't know how to proceed any further.
So what are the problems:
- Tearing with XBMC latest alpha and vaapi.
- VLC doesnt even work with vaapi at all (wanted to test with vlc)
- I managed to compile mplayer with vaapi support. It works flawless! Just cant get it to work
With SMPlayer frontend. So close, yet so far away.
What I have done:
I used the latest XBMC Gotham alpha from GIT, hence Frodo packages do not support vaapi ATM.
Compiled airplay support (libshairplay) and it works good.
Prior to this I installed libvaapi, libvaapi-intel-driver and stuff.
I even compiled latest intel vaapi drivers from latest source. Vaapi 0.34 and vaapi-intel-driver 1.2.
Same result.
My system:
As rock H77 mini-itx board.
Intel Pentium G2020 Ivy Bridge.
Fedora 19 x64
As you can see with my semi-success with mplayer, VAAPI itself is working perfekt.
With mplayer <12% CPU load, no tearing etc.
What I mean with tearing:
In the upper screen, there are 1-2 bad lines shifted vertically. Only with 1080p movies and when the camera is moving fast. Quite annoying, actually.
What bothers me that my xbmc build has no video-hardware settings so I cant change anything in the settings regarding video.
I hope someone has any ideas. I googled a lot and dit not find anything use full, yet.
What I have done:
Same result.
My system:
Fedora 19 x64
