2013-07-23, 22:20
I've been trying to understand a problem I've been having with a large MKV file (~8GB) on a DVD.
If I understand correctly, XBMC doesn't use the file system layer to access the DVD, it uses its own VFS layer. It seems that this layer is limited to 4GB size for files: this file stops playing at the 4GB boundary, while copying the file back on my hard drive makes it playable. Am I correct ? And if correct, what can I do to workaround this problem ?
