this is an addon for
InfinityList.com. It lists the most awesome action sport videos from youtube & vimeo.
The following categories are available: All, Bike, Climb, Extra, Motor, Parkour, Skate, Sky, Snow and Water. You can browse latest and most hyped videos per category.
I also implemented a mode to automatically play random videos - if you just want some awesome videos to be played in the background.
Note: To watch vimeo videos in HD, you have to change the vimeo.com plugin settings. Per default its SD only.
Install it via my
testing repo. When everything is ok i will add it to the official repo.
Have fun,
asde
v1.0.1 / 2.0.1:
- Fixed site changes
- Some other small improvements
The InfinityList.com add-on is now available via the xbmc.org eden/frodo repo...
For faster access I set InfinityList > All > Play Random to the Favourites List.
Playing from Favourites works, but there is trouble exiting. Pressing Stop or Back stops the currently playing video and exits fullscreen, however an empty list window is shown, and then the Opening Stream pop up appears and the next video starts playing, and this seems to be a continuous loop.
This problem does not occur if I access InfinityList normally (ie: not via Favorites straight to Play Random).
(2013-09-05, 17:34)jmh2002 Wrote: [ -> ]For faster access I set InfinityList > All > Play Random to the Favourites List.
This is a problem with the xbmc favourites script, i could change it in the addon but it would cause another problem...
For now, you have to manually change "ActivateWindow(10025," to "PlayMedia(" in your favourites.xml.
ok, Ill look into it, thank you
(2013-09-05, 21:33)AddonScriptorDE Wrote: [ -> ]This is a problem with the xbmc favourites script, i could change it in the addon but it would cause another problem...
This seems to have fixed it, thank you
I am getting error is this addon still on ?
(2014-04-11, 11:41)Cyber Wrote: [ -> ]Hi there!
Made an updated version of the Addon
Download Link
Thanks... and sorry: There was also a working version in my
testing repo but i forgot to post it here.
AddonScriptorDE
Really interested in the InfinityList Add-on, but when I tried to install it from XBMC official add-ons, it says it is incompatible. I'm totally new to this, so don't understand how to find out what the incompatibility is. I'm running Gotham 13.2 beta with Aeon MQ5. If you have any advice, would appreciate it. Thanks.
v2.0.5:
- Implemented Vimeo video url resolution
- Removed Vimeo addon dependency (not working anymore)
(2014-08-08, 19:51)Hiryu Wrote: [ -> ]AddonScriptorDE
Sorry for the late reply. Should now be working again...
This somehow does not work for me. Got all the time error:
ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.infinitylist_com/?url=30yYDcl7m6k&mode=playYoutubeVideo]
Btw, what's the problem with Vimeo?
According to this thread someone has fixed it
http://forum.kodi.tv/showthread.php?tid=81052&page=21
