Full Version: Recommended HTPC
Hey guys,
Currently I'm using an Apple TV 2 with XBMC but I would like to upgrade to something faster. Unfortunately ATV2 is really slow when browsing my +1000 movies library, switching menus, reading lists plus it doesn't support a fancy skin like AEON very well.
So, the idea is to replace it with something better on performance and that supports 1080p. Preferably a small device like ATV2 with a remote control.
What do you guys recommend?
http://forum.xbmc.org/showthread.php?tid=166880
From Dougie
or you can also check the recommendations from eskro
Thanks for the shout-out. I am working on getting an internal IR receiver/remote for these.
I was looking for something small and that has a remote. I don't want to have to built it myself. I'm comfortable with installing software and all but I would like to have the hardware "ready to go".
I was looking at these:
http://www.amazon.ca/dp/B00CJ38QES
http://www.amazon.ca/dp/B0088IGPM8
http://www.amazon.ca/dp/B00AX7FQU4
Do you guys know them? Are they any good? Are they faster than ATV2? I really want something that works with the best performance possible without the need to build a computer just for it.
Plenty of threads here about the MINIX and Pivos boxes, some even on the front page, with lots of experience and stories to tell.
