When I hit play in my top 100 folder it does shuffle play for some reason, playing in a random order not in the proper order, one after the other. Cant find a setting for this anywhere that I might have accidentally changed at some point. Thanks for your help.
After you start playing, open the slide-out menu on the left and look at the buttons below "Playing". Be sure the right-most button is not enabled (displaying an arrowhead within a circle on the lower-right corner of the button). If it is, just click on it to disable it and prevent random playback.
OK thanks. Actually the way I fixed it was to go to the slide-out menu after selecting "now playing" and unchecked shuffle which had been checked for some reason.
