2013-07-27, 03:42
2013-07-27, 03:42
2013-07-29, 03:45
I am having the same issue. I searched all over and have had no luck.
2013-07-29, 09:35
For now, there is no option for hiding this CD case.
But you can remove it by editing MusicVisualisation.xml file in 1080i folder from Aeon Nox directory and remove or comment (by adding <!-- line before and --> line after the code block) lines 303 -> 314 :
Warning : your modifications will be lost every time this skin will be updated (installing from ZIP or updated by XBMC from official repo when because stable).
<control type="image">
<posy>-270</posy>
<width>490</width>
<height>450</height>
<texture>thumbs/boxes/cd_shadow_light.png</texture>
</control>
<posy>-270</posy>
<width>490</width>
<texture>thumbs/boxes/cd_glass.png</texture>
</control>
2013-07-29, 17:40
Yep, without clear case, looks very ugly for me... that view designed with case.. Sorry.
2013-07-29, 20:40
Nox easter egg: when vinyl cdart is selected as fallback if no cdart -> clearcase is gone
watch gallery
2013-07-30, 17:11
(2013-07-29, 20:40)sergiocos Wrote: [ -> ]Nox easter egg: when vinyl cdart is selected as fallback if no cdart -> clearcase is gone
Sand in the Machine..
2013-07-31, 12:49
(2013-07-29, 09:35)mikebzh44 Wrote: [ -> ]But you can remove it by editing MusicVisualisation.xml file in 1080i folder from Aeon Nox directory and remove or comment (by adding <!-- line before and --> line after the code block) lines 303 -> 314 :
Just what I was looking for, thanks.
