Pages: 1 2 3 4 5 6 7 8 9 10
Only managed to get a few. I'll do some more tomorrow.
If anyone want's to see anything in particular let me know.
watch gallery
nevermind :p
I got a question, is it possible to get sets, actors, years back instead of "movies-sets, movies-actors, movies-years)
Since you are in a submenu of movies, its normal you have sets of movies
In dutch language theres too much text like that
See picture 3 above to clarify what i mean
(2013-09-05, 20:01)MarcosQui Wrote: [ -> ]Aeon MQ 5 1.1.2 - Beta 5 - available in Google Drive - Frodo version and Gotham version.
Changelog:
Added: New PVR - Many improvements over old version.
Added: Customization Selector separated by color category.
Added: Smart Submenu. Easy access to most important functions using submenu/arrow down.
Added: RCB - Wall view.
Added: Gotham version/video osd - button to access 3D mode.
Improved: PVR status - Recording/Timer - in Main Menu.
Fixed: Random Themes does not work properly.
Fixed: System Menu/Buttton Shutdown - action respect the settings in XBMC shutdown.
Fixed: Missing widgets for Vplaylist 1.
Fixed: CoverFlow view - appears to wrong content in some cases.
Fixed: Main Menu Customization - pressing the left in an empty item is not possible to return to the menu.
Changed: Action for shutdown menu to prevent errors on some systems.
In first post, new album, refers to current version Beta 5.
Feel free to post more pictures, especially of the new PVR.
thx !
Skank, use rename option for change titles items in submenu.
Can i rename all at once? or do i have to set each item one by one (this is a lot, since tvshows has it too)
Need one by one, it´s necessary because skin use concept replace for customize main menu and submenus.
Looks amazing. Thanks for the pics. Love the implementation of the disc art!
Samu-rai
Pic #2: What view is that? Really nice.
The other pics show fan art background for menu items. How did you do that? For the TV Shows TWD, really nice!!
What font do you use for menu bar?
Please, tell me!
Hi Ipaddle
Pic 2 - go to the furniture menu and set the bar at the bottom, and the widgets at the top as per the third from last screenshot. You'll then get the same view shown.
For the backgrounds of each button I select my favorite movie fanarts for example (I like promotional fanarts rather than the screen shot crap people upload), place them in a their own folder, then go to the main menu customization screen and choose 'use multiple images a background'.
The font is style 4.
Samu-rai
how did u got the description for the movie sets working?
what did u use?
Would be great if you could share that.
thx
Hi mydsmbr
You need to use phil65's
script.extendedinfo.
If you install this it will give you the sets info in ACE and MQ5.
It will also give you set disc art, which is cool.
thx man, i just found it. Works great!
Aeon MQ 5 - 1.1.4 Beta 6 - already available in Google Drive. Frodo version and Gotham version.
Changelog:
Added: Transparecy selector to Media Flags Bar.
Added: RCB - Panel view.
Added: Submenu for Live TV menu.
Added: Next Aired - Widgets for TV Guide menu.
Fixed: GlassList view - Missing Disc Art if using info panel in always visible mode.
Fixed: GlassList view - Media Flags layout.
Fixed: Status Widget - Text size to accommodate large titles.
Fixed: PVR - Minor details in layout.
Fixed: PVR - Missing Radio Channels Logo.
Fixed: Next Aired - layout and navigation errors.
Improved: Disc Art - Show/Hide during browsing in library.
Attention: This version has the 'auto reconfiguration', so you will have to redo the settings in some cases.
Comments, please, only in Brazilian forum. Thank you.
thanks! grabbing now to test!
(2013-09-12, 16:51)MarcosQui Wrote: [ -> ]Aeon MQ 5 - 1.1.4 Beta 6 - already available in Google Drive. Frodo version and Gotham version.
would love to see a screen cap of the RCB stuff if anybody would oblige
