Full Version: Twit Addon stopps working after 50 min
I'm having a strange problem using the Twit Add-on. After watching any of the streams, right around the 45-50 min mark, the audio will drop, and the video will go to about 1 frame every 2-3 seconds. If I close the video and reopen everything is fine for another 45-50 mins. I have tried different sources (all the 1 Mbps streams) Is anyone else having a problem, or any suggestions on what to look for? I am using a mac mini if that helps any.
Also just a minor inconvenience, the stream always seams to be about 10 seconds behind, any thoughts on how not to get the delay?
That is strange. You may want to ask in the forum section for your OS/build. The add-on basically just tells xbmc's player to play a URL. Capturing a log of this happening will be a major key in getting help, so check out -> http://wiki.xbmc.org/?title=Log_file and http://forum.xbmc.org/showthread.php?tid=47124
